Results 1 to 19 of 19
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    Default What do you use for under the front end?
    Other than an expensive skidplate have any of found anything to help the bottoming out issue? I found these SLiPLO products, and have been amazed at how easy they were to install, excellent price, and now I can go in and out of my driveway without tearing up the underside! https://sliplo.com/191.html
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    2020 RT Limited , Says Chalk White, but in person it is much more gray
    Northern Kalifornia
    I've often wondered, since I first scraped my RT, why people just don't seem to watch where the heck they're going?
    Mar 2015
    forrest above Reno, Nv
    Thumbs up Spring stiffeners
    I like the 3/8" thick, superior coverage, and yes, expensive bumpskid under the wimpy thin plastic under my Spyder. I also have spring stiffeners ( 2 per spring ) that did raise the about 1/2". I have seen a couple of gouges in the thick protective bumpskid and I am glad it's there.
    Lew L
    2014 RTS , Circuit Yellow
    Jun 2018
    HAYMARKET,VA
    Hoping to see more people that have actually used the SLiPLO bumpskids comment on how they have worked for them.
    Baja Ron Sway Bar
    Key Cover from Ebay
    Greenville Tx
    I got stiffer springs for my elka shocks. problem solved. Although I do recommend a skid plate. Those Slipos dont do much.
    2017 F3 Limited
    Greenville Tx
    Quote Originally Posted by AY4B View Post
    If you have problems bottoming out and have elka shocks, they will send you stiffer springs free of charge.
    2017 F3 Limited
    Dec 2015
    Oakley Utah
    Nothing. It has served me well for 25k miles
    2014 RTL Platinum
    SoFlo
    Nothing. However, the Fox Shox are certainly firmer, and I take efforts to enter possible areas that can scrape at angle.
    May 2018
    millsboro,delaware
    Fullsize bumpskid plus adjustable spring stiffeners.When I go offroading I turn the stiffeners up an inch or so.
    : 2017 RTL ORBITAL BLUE
    Jun 2014
    ny
    just soap & a sponge when in the shower
    Linden, CA
    Default This Protects your front end the best of all
    I have them on sale right now, The price shown
    is NOT your price I sell for much less...it's to late for Christmas deliv.
    but I will extend the low pricing after Christmas
    CALL ME 209-887-3283
    Merry Christmas
    Invalid Emails
    Feb 2020
    Splendora TX
    Hey Dave, do U have those 4 a RS??? Thanks
    Linden, CA
    Hi
    Dave here motorcycledave.com
    I am a Dealer / Dist. for Rivco and can save you money on this...WAY BETTER than anything else out there
    and you will have a great place to mount lights. Call me for Discount Price
    209-887-3283 Yes I am working from home like everyone else...
    Nov 2018
    Claremore, Ok.
    Hi
    Dave, I bought the aluminum skid plates from Rivco that are supposed to attach to those bumpers. I didn't read the fine print that says the plates ONLY attach to parts that come with the bumper. Color me PISSED, but my fault for buying excited. However, I did figure out a way to get them mounted. The plates work wonderfully. And to anyone that is considering buying the plates, read the installation instructions for the bumper and you'll see what part you'll need to fabricate. Or PM to me.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Active Member ssmcclub's Avatar
    Apr 2013
    massapequa ny 11758
    elka shocks work for me no more bottoming out
    richie spyder
    If you get your Spyder returned to the original ride height (where it sits before loading it up). You will reduce or eliminate your ground strikes. The key is to recover that lost 2 inches or more of ground clearance. This also has the benefits of maintaining your aliment and giving you more control and better handling. It is a shame that BRP no longer mounts adjustable shock springs on current Spyder models.
    Florida Swamp
    Got a bump skid plate under there, but mostly got dried possum guts and a layer of armadillo parts under there.
    2019 F3-S , Black & Silver
    Harrington, Australia
    Yeah, I had to upgrade my front shocks anyway, and haven’t bottomed out since the heavy duty Wilbers were installed.
    HeliBars Handlebars
    Kenda Kanine rear.
    May 2018
    millsboro,delaware
    The bumpskid will spread the shock of the hit across the full bottom of the frunk whereas the sliplo would let the force transfer to the area just above where it sits.I think the skid could take a much bigger whack without causing damage.
