Results 1 to 9 of 9
    Active Member BearX16's Avatar
    Jun 2019
    East Central IL
    Default 2014 RT S USB Cable Run from Trunk
    Seeking advice on running usb cable from the trunk to handle bar. Do's and don'ts and the best place to go through the trunk for running cable under seat. Thanks for any help on this project. Fred
    There should be a removable port blank on the left side of the rear wall of your frunk for a customer choice receptacle add-on. When I bought mine there was an option for a 12v cigarette lighter type receptacle or a USB one. It is directly below the left fuse box. Behind this blank is a pair of unswitched wires to power the receptacle. It would be a shorter and easier run to the bars to power your accessory and you wouldn't have to do any drilling and sealing of the trunk. JMO.
    Jun 2019
    East Central IL
    Thank you!
    Quote Originally Posted by BearX16 View Post
    What do you plan to use it for? Charging or data transfer? There might be a better way to accomplish what you need.
    Mar 2015
    Brockport, NY
    Default Add port from Battery
    I agree, I had originally run a 10' cable from trunk to handlebar, went through side of trunk and used rtv to seal it back up. I used that for about 1 year and then added a dual USB connector from the battery to the handlebars on my spyderdock.
    It was easier to install the direct wired front connection than it was to run the 10' cable from the frunk. FWIW
    2014 RT-S Pearl White
    May 2018
    millsboro,delaware
    On my 17rtl I found a dual port usb rocker switch(@10$),it goes where you have the empty spot on your rocker switch panel(not sure you have rocker switches on yours but they control the hand grip heaters and the fog lites).You have to remove the gauge panel and hook the 2 wires to the fuel gauge(others could chime in about the correct colors to hook up to).The port has dual outlets and a voltmeter in the middle so you can know if your battery stops charging,also a rubber cover to keep water out.
    : 2017 RTL ORBITAL BLUE
    Jun 2019
    East Central IL
    The cable will be used for charging only. It looks like I may going with center mount usb hub in the switch dock. Thanks Fred
    Jun 2019
    East Central IL
    The cable will be used for charging only. It looks like I may going with center mount usb hub in the switch dock. Thanks for taking time to reply Fred
    SoFlo
    Regarding the connection to get power for the USB. Be very considerate about how you route the wires. Obviously to avoid inducing noise into the existing wire harnesses, but also from a maintenance standpoint.
    Spyders can be a bit fickle to work on, and often require disassembly of major subassemblies to gain access. If you have a wire route from the power source to your USB, avoid routing the wires in a way they are retaining a major subassembly.
    A friend that worked as a Spyder tech, explained how poorly routed wiring creates a huge added time expense at dealerships, and not something covered by warranty.
    Also, consider purchasing oem style waterproof connectors that are easily disconnected when needed, vs powertaps or similar that may be more permanent or difficult to remove if needed.
    As an example, when I added rear trunk lights, I utilized the same switched light circuit as the frunk. By fabricating a split pigtail using oem style connectors, I can easily disconnect as needed for frunk removal. At the aft end, I installed a second oem style sealed connector. This allowed the trunk to be easily removed without removing the entire wire harness I made.
    Also wanted to mention, shop wisely for your USB port. If the USB will be exposed to weather or washing, consider a higher quality sealed type.
