Results 1 to 10 of 10
Thread: Fog Lights
    Oct 2013
    rome new york
    Default Fog Lights
    Has anyone done something different with the black fog light blanks besides adding fog lights??
    Just wondering
    Active Member boz329's Avatar
    May 2017
    Toledo Ohio
    Pierre from www.canamspyderaccessories.com has a color-matched front fog light casing replacement that extends across the hood as well. Really sharp and not too expensive.
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    I installed the RIVCO driving light kit. Super bright and the beam really reaches out
    2022 RT Limited , Silver w/ Black and Purple accents
    Active Member SpyderF3's Avatar
    Nov 2016
    Hummelstown.Pa.
    I just installed a set of these, https://www.ebay.com/itm/Can-Am-Spyd...53.m2749.l2649
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by boz329 View Post
    I've sent several product requests to the above re: gloss black housings with zero replies. Maybe I need to call them but not impressed, at all, with their CS
    2022 RT Sea To Sky
    Active Member always young's Avatar
    Oct 2015
    Melbourne, Fl
    Merry Christmas. I installed a set of LED semi trailer side marker lights (orange) in this location. They come with a rubber gasket for mounting and fit perfectly in this location. I carefully cutout the hole to fit them. They just slide in an are held tight on their own. They are the extra bright 5 element LED type and cost about $10.00 a piece online or at Northern Tool. I don't know how to add a picture but you can see them in my signature picture. Enjoy!
    Life is attitude, be positive!
    Mar 2017
    https://www.northerntool.com/shop/to...0748_200580748
    Just throwing out the link. Probably not right tho
    Dec 2013
    Quote Originally Posted by Rattlebars View Post
    That's fine Rattlebars. You could've even thrown in a description telling us it was a link to the Blazer Incandescent Round Clearance Marker Lights that you've used or found.... It's 'adverts' or 'quotes of adverts' that are frowned upon.
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Active Member Nobodyjj's Avatar
    Sep 2018
    Caledonia,Ontario,Canada
    Open them up and duct more air into the cowl area.
    Mar 2017
    Quote Originally Posted by Nobodyjj View Post
    If you are going to make vents of the opening, get the OEM shrouds. I'd give a link to them but I sure as gosh don't wanna get scolded for nothing again.
