Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: Cheap Lift
    Very Active Member h0gr1der's Avatar
    Apr 2019
    USA
    Default Cheap Lift
    25% off sale here (thru the 15th); https://www.harborfreight.com
    One of the jacks that actually fit under a Spyder here; https://www.harborfreight.com/1500-l...ift-63397.html
    $169.99 -25%= $127.49 plus tax. It's Chinese junk, but will get the job done without a whole lot of cash outlay.
    h0gr1der
    2018 RT Limited Blue/Chrome SE6 *Tri-Axis Bars*Adjustable Driver Backrest*175/55R15 Vredestein Front, 205/60R15 Vredestein Rear Tires*Baja Ron Front Spring Pre-Load Adjusters*Misty Mountain Sheepskin seat cover*Centramatic balancers *Garmin Zumo 595LM GPS*KOTT Grills*BajaRon swaybar*SpyderPops Alignment*Missing Belt guard*Magnetic Mirrors*Custom Rear Adjustable Shock*360° LED Headlights & Foglights*Progressive front fender turn signals
    States Visited on Less than 4 wheels.
    Bryant, Arkansas
    Just go ahead and buy a decent jack, your foot will thank you later.
    Anonymous
    Jul 2018
    Fountain Hills,AZ
    Any pics on this with a spyder rt on it? Lifting point location?
    Apr 2019
    USA
    Quote Originally Posted by wilpir View Post
    I have no other information on this other than it is one of the ones that works and is like the more expensive Craftsman. It is not specifically for the Spyder, as most of the jacking solutions, so jack-stands are in order at the least.
    h0gr1der
    Active Member MeudtPG's Avatar
    Aug 2018
    Monroe, WI
    This is a solid jack and it works fine for my Spyder RTL. At $127.49 (if you can get it for this) is a no brainer.
    I paid $166.67 including 5% tax a year ago.
    Pittsburgh® Automotive- item#63397
    •High strength, lightweight aluminum construction
    •Lift range from 3-5/8 in. to 17 in.
    •Saddle extensions add 2 in. to max lift height
    •31-1/2 in. extra long handle for easy lifting
    •Locking bar for safety
    "BLUE STAR – She shines so brightly"
    2018 SPYDER RT LTD SE6 BLUE/CHROME
    2018 RTL , Large Brake Pedal (cut 1/3 off). Oxford Blue/Chrome
    Oct 2016
    Faribault, MN
    I have used this very jack for my '13 RTL, let's see, numerous oil changes, frunk removal, rear cargo section removal, BajaRon Sway bar upgrade, Front shock spring adjusters, and more. I do always use jack stands for additional support when it's up in the air.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Nov 2018
    Waynesboro, PA
    I have one that I use to lift my RTL. I lift the RTL then place 3 jack stands under the bike then remove the jack and do my oil change or what ever other work I need to do. I use the jack with the extensions when I lift my lawn tractor. Handy jack just to lift. I would not move the bike when on this jack, if you want to do that get a better jack.
    My Spyder
    2012 RTL , Brown
    Sep 2016
    Chillicothe, Oh.
    I have the Pittsburgh jack and couldn't be happier with it. I had a Craftsman when I had my Valkyrie and you couldn't run fast enough to give me another one. Mine was junk.
    2015 RT , Black
    Aug 2019
    Stoughton, WI
    Does the F3 have the same lift points as the RT ?
    2022 RT Sea To Sky
    Apr 2019
    USA
    I bought this today based on some very positive reviews I've read here about it. I will lift my Spyder before the rather short warranty runs out, this Chinese stuff either works or it doesn't, you just have to keep swapping until you get a good one. I can't afford one of the Big Blue or other better lifts, and I believe this one will be suitable for my home mechanic chores.
    h0gr1der
    Very Active Member cruisinTX's Avatar
    Mar 2015
    Fritch, Tx
    I bought the Harbor Freight lift (older style than in the link above) back in about 2001 to facilitate changing tires on a motorcycle. It has been stone cold reliable ever since and I have used it on the 2014 RT Limited to change the rear tire. Very satisfied with it.
    Those who say " I can't" will always be right.
    2014 RT Limited , pewter (magnesium?)
    Member BillyChampagne's Avatar
    Sep 2019
    SW Florida
    Quote Originally Posted by MeudtPG View Post
    DITTO...
    I bought mine 5 months ago and it is solid. Paid 189 bananas. I use ramps instead of jacks.
    Spyder 2018 RTL - Metallic Champagne
    Just cause you got the monkey off your back doesn't mean the circus has left town. - George Carlin
    2018 RT LTD , Champagne Metallic
    Feb 2019
    Portland, Oregon
    For lifting just the rear wheel or one front wheel, I use this one and find it to be better quality than the price suggests. That makes it a real bargain - especially when bought with a coupon.
    https://www.harborfreight.com/15-ton...ack-64545.html
    Idaho
    Quote Originally Posted by Navydad View Post
    Interesting you say that since, from what I see looking at them, the same style jack with either the HF label or C label comes off the same manufacturing line!
    2014 Copper RTS
    Feb 2019
    Portland, Oregon
    I have seen many items that HF sells at other stores with some popular brand name on them and selling for much more. Same thing with Cycle Gear riding gear. Same item with a popular brand name and costing more.
    It pays to shop and compare.
    Apr 2019
    Clinton, MS
    Don't you just love the light weigth of that thing. Breeze to move around.
    Jul 2014
    Mint Hill, NC
    My son bought the HF model several years ago, didn't have it too long before the cylinder began to leak but was out of warranty. He followed instructions about tightening different thing and replenishing the cylinder fluid which appeared to fix it but every time he lifted his BMW 1200 GS Adventure when he went to lower it it was very jerky going down. I was looking for a lift at the time and based on son's experience purchased a Craftsman that works smoother than deer guts on a door knob. YMMV.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Apr 2019
    USA
    I'd be real interested in a side by side Craftsman vs HF 63397 technical comparison. I know with all the intellectual and patent theft that anything can be copied in China, and to me both the yellow Craftsman and the blue HF look like they came off of the same assembly line. Not sure if applies to this particular lift, but I've read that if you open the bleed wide open in one go some of the lifts do a smooth metered release. Not sure how I'm going to test this one safely, but I want to know.
    Craftsman Here- https://www.searsoutlet.com/br/pdp/c...atv-jack/16395
    Harbor Freight Here-https://www.harborfreight.com/1500-lb-capacity-atv-motorcycle-lift-63397.html
    h0gr1der
    Mar 2015
    forrest above Reno, Nv
    Thumbs up slow release
    Quote Originally Posted by h0gr1der View Post
    My old, yellow HF lift, as described above, will give a slower drop if the little foot lever is pushed down all the way. I has not given me a bit of trouble in the 7 years I've owned it.
    Lew L
    2014 RTS , Circuit Yellow
    Apr 2019
    USA
    Just unpacked the HF 63397 lift, the instructions say to lower the load slowly and incrementally turn the handle counterclockwise. This indicates it has no orifice bleed function, as described by Mr Lew L for the older style lifts. Has anyone that uses this exact lift ever noticed if it does or not have controlled bleed? How about the Craftsman guys?
    h0gr1der
    Nov 2018
    Waynesboro, PA
    Just turn the handle counter clockwise slowly to bleed, try it with out anything on it first. Note there is a lock / positive stop on it that will stop it from coming all the way down, make sure you get that out of the way. When the jack starts to lower stop turning, let it come down as slow as you can or just open it all the way and it will come down fast.
    My Spyder
    2012 RTL , Brown
    Sep 2017
    Durham,Maine
    I am thinking that with a little fab work that 1000lb motorcycle lift would be just what the doctor ordered!! All three wheels in the air on a good base and up in the air!!
    2012 RTL , Pearl
    Nov 2018
    Waynesboro, PA
    I lift my RTL all 3 wheels at the same time as is then place the Jack stands under the Spyder. The lift is 1500 lbs. rated.
    My Spyder
    2012 RTL , Brown
    Jul 2014
    Mint Hill, NC
    ...both the yellow Craftsman and the blue HF look like they came off of the same assembly line....
    Son's HF is a yellow one. Manual doesn't have specific instructions just for bleeding but refill instructions say to turn it over to completely empty then refill w/- 5W hydraulic oil and then quickly pump handle 6-8 strikes to remove any air in system and reinstall oil fill cap.
    Cognac 2014 RT-S
    May 2017
    Mesa, Arid-Zone-A
    My HF jack has worked without issue. It will lower slowly if I use a gentle adjustment. Paid 50 bucks for it used, from Craigs List. More than paid for itself many times over. I think ANY reasonably priced lift will do the same..... Jim
    Semper Fi
