Results 1 to 5 of 5
    Linden, CA
    Default So you say you want a gas door for FREE !
    Hi Everyone
    I get calls and emails all the time regarding the FREE GAS DOOR
    well it's still FREE, It's an easy DO IT YOURSELF mod you can do
    with the tools you have around the house and about 1/2 hour of your time.
    This is a photo of the gas door installed, can you see it?
    if you do not see it check my NEXT POST.
    Linden, CA
    Default Gas door post #2
    Now you can see how it is done, all you do is mark where you want to
    cut the plastic pan ( NOT THE UPHOLSTERY OR FOAM ) by doing this
    you have made a door and are using the foam and vinyl as the hinge.
    EASY
    you can cut the plastic pan with a sharpe box cutter or if you have a dremel use that.
    Check it out before and after.
    Danbury Connecticut
    It seems like a great idea on the face of it, and yes, very easy to implement.
    Would you also need a little velcro at the front to lock it in place?
    I'd be concerned about the reliability, though.
    How many fill ups does it take, until the vinyl disintegrates ?
    Just my opinion, I could be wrong, and if I am, I'm sure someone on this site will let me know.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Linden, CA
    At this time I have done about 80 or so and not one has failed, velcro is an idea as you see in the first photo
    but not always needed. when I do them here in the shop I take the foam and peel it back and put some
    seat belt material on the pan just for insurance and glue the foam back in place it will never fail.
    Nov 2018
    Claremore, Ok.
    I like free stuff .
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
