Results 1 to 9 of 9
    Nov 2019
    Kansas
    Default Got my first spyder delivered last night. A few questions
    So it is a 2016 F3-T with 8800 miles on it. So a couple things.
    Not sure how to open the saddlebags on the back each side. Please don't laugh
    Also I would like to move the peg on each side to as far away as I can, and not sure how to do that either.
    I appreciate the help.
    Vermont
    Sorry I can't help you with your questions, someone with an F3-T will chime in with answers to your questions.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    Quote Originally Posted by acdcking12 View Post
    The saddlebags open by lifting on the lever circled in red in the attached picture. If it's locked, you use your ignition key to unlock it.
    To move the pegs, there are 2 bolts under the peg on the rail. They have lock-tight on them, so heating with a torch first is a good idea. Once the the bolts are out, you open the clamp part of the peg and move it forward - the clamp part of the peg has a pin that fits in one of 5 holes on the inside of the rail. You will need the proper brake rod and shifting rod(if it's a manual) to match your peg position.
    Mike
    2020 RT Limited , Petrol Blue
    Sep 2015
    Cold Spring, MN
    acdcking12, I would also suggest that if you didn't get a manual with your bike, you go online to view and read the manual for your bike. It will help with many questions that may come up. Here's a link. http://www.operatorsguides.brp.com/I...b-89e605052f28 Chose "Roadster" in the drop down menu in the upper left corner, than chose your year and model.
    Enjoy your new to you F3-T!
    Mike
    Nov 2019
    Kansas
    Thank you. They were unlocked already. I looked at the ignition key and did not see a way to lock them back up. I do see a key hole above the saddlebags. But Unable to lock them that way. I am starting to think that maybe they are not stock saddlebags and are 3rd party?
    Mar 2013
    Maumelle, AR
    Post a side picture of your Spyder. Maybe it's not a T.
    2020 RT Limited , Chalk
    Mar 2017
    T's have OEM bags but no top case.
    Oct 2014
    Idaho
    Congratulations
