Results 1 to 10 of 10
    Active Member davehirst's Avatar
    Feb 2017
    Christiana PA
    Default Removing panel to install new gauges
    I would like to go with the digital information for fuel and temp, but can't seem to get the panel out far enough to remove the existing wiring. Is there some secret I don't know about?
    (I know I spelled gauges wrong)
    2015 RT S , None Tried one, but took it off. Didn't like it Black and Silver
    Feb 2017
    Christiana PA
    Default Removing gauges
    How do I get the panel out far enough to remove the gauges to go digital. I have a 2015 RT S and can't seem to get the panel out far enough to to get to the wiring. Seems to be hitting on the plastic cover on the handlebars.
    Aug 2016
    Beloit, Wi
    Turn the handelbarsall all the way to the right or left. I have removed my dash and replace the factory gauges with a voltage gauge on one side and a USB plug on the other. Very simple to do.
    Thank You
    Mark Light
    Live Long and Ride Hard
    Quote Originally Posted by davehirst View Post
    Been there done that ….. If you have Needle nose pliers it's a lot easier, if they are the angled variety - even better …...good luck … Mike
    Again - needle nose pliers ……… Mike
    Active Member LongIsland's Avatar
    Dec 2018
    Long Island
    canamspyderaccessories.com has a multitude of videos showing on how to add/change things on the spyder. Additionally a google search of RT Can Am Spyder Dashboard removal and then clicking on video brought many more videos done by members of this board.
    Very Active Member bmwlarry's Avatar
    Mar 2012
    Beaverton, Oregon
    Once you get the four screws out slowly pull out the gauge surround. The handle bars need turned to side enough to have a flat surface facing straight up.
    2015 an Am Spyder RT Limited
    2013 Yamaha WR250R - Sold
    2011 Can Am Spyder RT-S SE5 Limited - Sold
    2011 Aspen Sentry Trailer
    2003 BMW K1200LT - Sold
    2007 Unigo Trailer - Sold
    2001 BMW K1200LT - Sold
    2001 Honda 750 NightHawk - sold
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    Vermont
    Go to "My Albums" to see pictures of what the dashboard looks like with the dashboard removed. Page 4 titled"Dashboard 2014RTS-SE6 in Cognac". Sorry no link.
    You will see on the left side 2 wires red/blue with connectors ( that go to the Gas gauge) and on the right side 2 red/blue wires that go to the temp. gauge. You will need needle nose pliers, to remove the 2 connectors ( remove these gently). Be sure to put a soft cloth over the ignition switch so it does not scratch it.
    Deanna
    Last edited by Deanna777; 12-12-2019 at 12:25 PM. Reason: added to post @ 12:25pm.
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Vermont
    "My album" shows a picture. Page 4 Titled " Dashboard 14RTS-SE6 in Cognac".
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Feb 2017
    Christiana PA
    Thanks for the info. Turning the handlebars is probably what I am missing. Will try again when I have some time.
