Results 1 to 13 of 13
    Mar 2015
    forrest above Reno, Nv
    Question Snowblower conversion question.
    So I already have a hot rod blower. A 10 HP motor on a 5 HP 24" frame, which after an impeller and governor mod ,works pretty good. But my ? is:
    Do any of you snowblower experts think a 2 stage machine could be converted to a 3 stage blower
    with a few ( expensive ) parts??????
    Lew L
    2014 RTS , Circuit Yellow
    Quote Originally Posted by Lew L View Post
    Lew L
    I had a distance throwing issue with mine ….. I added hard rubber extensions to the existing metal paddles on the impeller …. they come much closer to the metal than the oem ones did...… My machine now throws about 10 ft. further...… I think you have plenty of HP at 10...…. good luck …..mike ……… My concern with the Three Stage machines is heavy wet snow … the more contact with moving parts the higher the strain on the machine ….. I think it will bog down easier …..
    Faribault, MN
    Yep, on Youtube check out the video titled
    TEST snow blower Impeller Modification with and without
    by sixtyfiveford and there are many many others that make their two stage throw much further, there's even folks selling the rubber paddles on EBay pretty cheap if you don't have your own material available.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Lew L
    Easy. Give the two stage to Goodwill and go to Lowe's and buy a 3 stage! How much easier do you want it to be???
    Northern Kalifornia
    After the installation of rubber pads on the impeller, line the chute with plastic. Helps to keep it from clogging up.
    Florida Swamp
    See how the cost compares to a plane ticket to Miami.
    2019 F3-S , Black & Silver
    What's a snowblower?
    I know, I know, there always has to be a smarty.
    Mar 2015
    Well thanks guys. I did the impeller mod on both of my blowersyears ago and did it on a neighbors machine also. It does work. This year I exploded the auger gear box and broke both drive belts. Ingested a frozen /unopened pine cone. The parts are on order.
    Lew L
    Active Member Greven's Avatar
    Oct 2019
    Sweden
    Hot rod snow blowers, now this is a thread that really needs more pictures!
    Quote Originally Posted by Greven View Post
    Faribault, MN
    Safe Rides,
    IBA 70020
    Mar 2015
    It doesn't look any different than the original 5 HP other than the 10 HP the motor. It's a sleeper so to speak.
    I had a Honda CB 900F----- with 750 F side covers. A sleeper so to speak.
    My second 66 Mustang was just a plain jane white Mustang with a modified 289 HiPo motor. A sleeper so to speak.
    Even the with the ECU upgrade and stock pipes------- A sleeper so to speak.
    Lew L
    Active Member fjray's Avatar
    Aug 2015
    central oregon
    Don't forget to blend your own oil and set the tire pressure to 18. I run mine at 15 on the left cause my driveway is circular so it handles better at hot rod speeds.
