Results 1 to 19 of 19
    Very Active Member wmh9680's Avatar
    Nov 2015
    Tinley Park, Il
    Default raising her rear end (tire) off of the floor
    Good Evening, What would be the best way to raise the rear end off of the floor (I have all 3 wheels up on crates about a foot tall) so I could start her up and go thru the gears in the winter time in my garage? I never put her to sleep in the winter. Thanks, Mike
    2014 RT Limited Matte Silver, Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars,
    Will it ever stop--NO
    Feb 2019
    Portland, Oregon
    For what purpose do you want to start it? If it isn't to go for at least a half hour ride, there is no good reason to start it. Starting it and running it for a few minutes does more harm than good. Think condensation and rust and more bad stuff.
    Mar 2013
    The issue you will have is that the computer will sense that the rear wheel is moving, but the front ones are not and throw a code. One of the reasons that you cannot dyno a spyder like you can a two wheel motorcycle.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Nov 2015
    Tinley Park, Il
    If I do start it I would always run her for a half hour or so with a fan blowing the exhaust out of the garage.
    Nov 2015
    Tinley Park, Il
    Would the code clear and go harmlessly away when I actually took her for a ride or would it cause more problems?
    Jul 2014
    Mint Hill, NC
    Use fuel stabilizer, a battery tender and forget about running it.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Sep 2017
    Durham,Maine
    Quote Originally Posted by PW2013STL View Post
    I roll mine when I adjust the belt, it's never thrown a code!
    2012 RTL , Pearl
    Sep 2017
    Durham,Maine
    Quote Originally Posted by wmh9680 View Post
    Put the fan in fount of you and sit on her, rev the gas and close your eyes and think of your happy place you want to ride to!!!
    2012 RTL , Pearl
    Mar 2013
    That will not throw a code, but the OP is talking about running through the gears. That will.
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    You are getting good advice here about not doing it. You should heed that advice.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Default engine running in winter
    with all the other wise folks here … don't run it even for 1/2 hr. …….. there must be a reason you think it's a good idea ….. Please share that reason with all of us …… Mike
    Sep 2009
    La Valle, WI
    Why does a Spyder throw a code when dynode and a 2 wheel bike with ABS doesn't. I had and Indian Chieftain with ABS and watched many get dynode without codes coming up.
    2018 F3 Limited , Oxford Blue
    Northern Kalifornia
    Quote Originally Posted by JP58 View Post
    Because it is not an Indian.
    Mar 2013
    The Spyder monitors the wheel speeds for it stability and traction control as well as its ABS. So the rear tire moving at a greater speed than the fronts tells the computer that something is wrong and will try and control it.
    Jul 2019
    UK
    Yes it will. Once the system finds all parameters to be correct it will begin to function normally.
    Rule#2: Never argue with an idiot. He'll drag you down to his level & then beat you with experience.
    Rule#1: Refer to rule #2.
    Sep 2014
    USA
    I ran mine a time or two and never threw a code. Just throw a battery tender on it and wait till spring.
    Idaho
    Think of all the scenarios where a Spyder will stay upright with wheels turning at different speeds, but a two wheeler won't. The likelihood at some point in time of a Spyder slipping and sliding and staying upright is 100%, whereas for a two wheeler it's almost 0%. Both bikes are designed to cope with what will happen, not for what probably will not happen. The codes come from the VSS, which monitors the Stability Control System, Electronic Brake Distribution System, and the Traction Control System, in addition to the ABS. I'll bet your Indian didn't have the other three systems.
    2014 Copper RTS
    Nov 2015
    Tinley Park, Il
    Thanks everyone question answered very well. Now get out there and ride if ya can
    Nov 2018
    Claremore, Ok.
    On my 2014 Triumph Trophy the ABS can be turned off if desired (for laying rubber/wheelies) and I imagine most modern computer controlled bikes can also be turned off if needed for a Dyno job, but the Spyder Nanny is a jealous bitch and just won't allow herself to be ignored.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
