missing mirror clip
Good Evening, Hope everyone that can is still riding. Here in Chicagoland we never got our Indian Summer for a few last rides. Well when I took my tupperware off for an oil and filter and air filter change I noticed the top clip on both mirrors were missing. Is the top one the common one to be missing. I think I'm gonna get me some magic mirrors for Christmas. Thanks, Mike
2014 RT Limited Matte Silver, Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars,
Will it ever stop--NO
" the top clip is missing " …. how is this possible, unless the mirror fell off that piece can't possibly dis-appear from the inside of the housing ….. my Guess is this occurred at your dealer during servicing ….. I think you should get them to fix their error ….. good luck …. Mike
There is no top clip on RT mirrors. The top part is a round disc called a Housing, PN 219800158, with an inverted U-shaped notch in it and is held to the mirror by two Phillips head screws. The Housing fits on a Spherical Head Stud, PN 705004323. Improperly attempting to remove mirrors can easily break the Housing.
Go for the magic mirrors. You will love them!
Yellow 2013RT SE5(Previous)
Champagne Metallic 2017RT LTD SE6
operator error, I forgot the top one dn have a clip, thanks everyone, I just ordered the Magic Mirrors. Thanks again, Mike
Ozzie Ozzie Ozzie
........ Well when I took my tupperware off for an oil and filter and air filter change I noticed the top clip on both mirrors were missing. Is the top one the common one to be missing. I think I'm gonna get me some magic mirrors for Christmas. Thanks, Mike
That's a pretty good thought for a Christmas present Mike!
Those top 'clips', or more properly, the top 'U shaped notch' fittings on the RT mirrors either breaking thru use or being broken by 'ham fisted techs' was one of the major reasons that drove the initial development of the Magic Mirror mounts.
Maybe it's our rough roads, or maybe it's cos we get access to fewer specialist BRP trained techs, but for whatever reason, here in Australia most Spyder RT Ryders with mirror issues had clearly identifiable problems with those top fittings losing their guts & failing well before anyone even thought about the bottom wire fittings spreading/bending & becoming an issue! So the Magic Mirror mounts were initially developed to address the replacement of just the top fittings; but while we were in there thinking about how to make the top mounts work properly & easily every time, we thought "why not change ALL the mounts & make the whole neanderthal mirror fit/re-fit thing a lot gentler & easier?" The 6 magnet Magic Mirrror sets were the result - no more OE mirror fitting issues at all, regardless of which particular fittings are failing on your mirrors!
The only draw-back I can see about getting yourself a set of Magic Mirrors for Christmas will be that you might not get to play with them after installation anywhere near as much as the rest of us have, especially if your Spyder goes into winter hibernation.... Those of us who don't hafta contend with hibernation & the subsequent Spyder deprivation usually get to fit them & then we just can't resist repeatedly taking the mirrors off & letting them jump back on again, even to the extent of fabricating excuses to do that, just cos mirror removal/re-fit with Magic Mirrors is sooo much more enjoyable & easier than it ever was with the OE mounts!
Merry Christmas!
I never totally put her away for the winter. I have a 5 mike course I lay out and on a day when the roads are dry and clean I take her out for a spin but I am jealous of your weather
If you take your Spyder out for a ride and don't go a distance that allows the engine to completely warm up, that is getting the engine oil to full operating temperature,which will be dependent on the ambient temperature of the day, you will wind up with condensation in the oil -- bad juju.
I always let her warm up 1st before I take her out
Well I got my Magic Mirrors and put them on and they work great and are a very easy install.
I can vouch once again that you have to be very careful with them or they will smash a finger trying to mate to one another. Once before I ordered my own magnets and got my finger smashed between two of them and now it happened again. The ones I got before all broke on me when they kept clanging together. This time I got a little blood blister. Oh well.
well that's better than me. had 2 in my hand, wanted to show wife how strong they were. well, look honey, let them smash together, and they broke!!!!
I also have the Magic Mirrors, I have no regrets.
I installed the Magic Mirrors my self.
You can go to Gallery " My Albums" on page 1 for pictures.
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
I found some the exact diameter and the hole was the right size but I broke all but one just handling the. I thought I could jb weld them back together but their polarity becomes independent with each one and the parts do not stay together yn the same pattern as the were before to make them hole again. I could have make my oun magic mirror kit but didn't. Gettin lazy and impatient in my old age I guess. Thanks, Mike
Did you piecemeal your magic mirrors together or buy a kit?
Magic mirrors
I bought LaMonsters kit
cant get out and ride even if it was nice in Illinois. at least we can excercise and get out some.
everyone stay safe. so far our county has no positives as of yesterday.
[joyce & irvin toms]
Yep, Get the Magic Mirrors, they are great. Also get the lanyards to hold them in case they come off. Not likely during normal driving, but in an accident I had in May, when another motorcycle rider pulled out in front of me, I lost both in the impact and it pulled the wiring harnesses apart from the inside. They were replaced in my rebuild.
2016 RTS Special Triple Black, BRP Freedom Trailer, Spyder Pops Rear Lighting Kit, Spyder Pops Full view Turn Signals, Trunk Light, Rivco Highway Pegs. Doc's Spring Tensioners, Trunk Organizer, Magic Mirrors, Foam Grips, back to Stock Windsheild, Lamonsters cat delete, Bajaron sway bar, More Farkles to come !!
