Page 3 of 3 FirstFirst 123
Results 51 to 64 of 64
  1. #51
    Active Member T.P.'s Avatar
    APPLE VALLEY, MN
    SoFlo
    Quote Originally Posted by T.P. View Post
    I would be very careful stating that. From experience with 5.1, it does not do well over time. The fluid forms crystals within itself. The crystals get lodged into various sealing surfaces, even rendering master cylinders inop.
    Yes 5.1 has a higher dry and wet boiling point, but high quality Dot 4 is very close and has no long term issues.
  3. #53
    Apr 2012
    Arizona
    I saw mention of 4 bleeder valves. I see 3 where is the 4th ?
  4. #54
    Quote Originally Posted by MrBones View Post
    If you're talking about the brake bleed outlets on the Spyder's calipers, there's one on each wheel, making up the 3, and one on the ABS Module, making it 4 all told!
  5. #55
    Feb 2019
    Portland, Oregon
    The ABS unit takes a larger Speed Bleeder - a 10 mm thread, I think. The calipers take a 6 mm thread.
  6. #56
    Jul 2016
    Huntsville Ontario
    FYI: Use DOT4 only. Never use DOT5 synthetic - that's for racing - unless the manual calls for it.
    I was wandering around WalMart this evening, and they were selling DOT4 synthetic. Should I stay away from that too?
    ....brian
    2016 RT Limited SE6
  7. #57
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by BrianO View Post
    The problem with syn brake fluid is it isn't hydrogenous (absorbs water) so the moisture the braking system absorbs travels down to the lowest points - the caliper pistons and can cause corrosion there with dire results.
    Although DOT4 does absorb atmospheric moisture, that is a blessing, as it doesn't collect in the calipers. When your brake fluid becomes tan, that's the moisture it's absorbing and a system bleed is needed.
  8. #58
    Jul 2016
    Huntsville Ontario
    Has anyone ordered speedbleeders recently and installed them? I read on other threads that SB8125L is the incorrect size for Spyders.
    2016 RT Limited SE6
  9. #59
    Mar 2015
    forrest above Reno, Nv
    I should be getting a set of 6mm bleeders from " them" SOON. I'll post up upon install.
    Lew L
    EDIT: I should be getting them in the mail today according to tracking.
    2014 RTS , Circuit Yellow
  10. #60
    Feb 2019
    Portland, Oregon
    My bike took the SB6 125. They originally sent SB8 125 and that was too big.
  11. #61
    Mar 2019
    NEBRASKA
    I've used speed bleeders on my Yamaha Venture and Victory Vision (and clutch). Just bought an 12 RT with 3300 miles. I'll give the Speed bleeder folks a buzz. I'm sure the fluid hasn't been changed and my pedal is a bit soft-I've seen some speed bleeder # discrepancies so I'll get some more info..I really do love these things. No help needed!!!
    If I do need SB6 125 for a 12 RT that'd be useful info.
    2012 RTL 14 RTS , Pearl White @ Pearl White
  12. #62
    Feb 2019
    Portland, Oregon
    Dave...If your brake fluid does not look like new and is tan to brown, that's water content and it needs changing.
    We are birds of a feather Dave....I had a '83 Yamaha Venture and a '92, then a 2010 Victory XR. Now I'm enjoying the heck out of my Spyder.
  13. #63
    Mar 2015
    I had to return the SB8 125L speedbleeders for the SB6100 #. They fit perfect on my 2014 RTS. Brake bleeding is FAST.
    Lew L
  14. #64
    Apr 2011
    GREENVILLE, SC
    $300.....?????
    come over to my house and i'll do it for $250.....
    $300 is STUPID-CRAZY.... i got a VACUUM BLEEDER @ HARBOR FREIGHT: https://www.harborfreight.com/brake-...kit-63391.html and 1 qt of new DOT 4 @ AUTOZONE and it took me under an hour and 1 beer.....
    Dan
    SPYD3R
