Results 1 to 12 of 12
Thread: ECU flash cost
    Default ECU flash cost
    What price range are we looking at to have a Monster Fuel stage 1 flash done on the 1330? $200, $500, $1000? I'm coming up empty searching for it and don't find a price schedule on Monster Fuel web site. From all I read here and the MF site it sounds like it's a well developed and worthwhile upgrade. I got to thinking maybe it's what I need to get the top end power and torque I wish my RT had when it comes to passing semis at 70+ mph on the Interstates.
    Northern Kalifornia
    Here's a start for you IdahoMtnSpyder , https://wick-itperformance.com/ and I see where they start at $391.
    Nov 2017
    San Francisco Bay area
    I’m with you looking for another boost when I need to pass.
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    2015 RTL , Yes Pearl White
    Thanks. When I got to thinking a bit more I realized the flash is just the first cost. I'm one of those who runs on regular gas, not premium. Monster Fuel pretty much requires you to run 91 octane minimum for Stage 1 flash, so I would have a continuing additional cost for the gas. Of course, if an owner always runs 91 already per BRP recommendation then that's a non-issue for him/her. For Stage 2 flash MF absolutely requires you to run 91. Don't even think of using 87, even in an emergency.
    But let's not get into a 91 vs 87 octane debate. That's been plenty enough already. If you remember my thread of a year or two ago I had better results with 87, believe it or not!
    Jul 2019
    Blk Hills & MN
    Me too on the flash. I thought it was about $300.00-$400.00?..ck here:
    https://www.monsterfuelinjection.com/
    Aug 2019
    Stoughton, WI
    Yeah .. Once the timing parameters are changed in the flash, 87 octane goes out the window. I'm kinda in the same thought process as I'll be purchasing a Dynojet PV3 tomorrow. Nice thing with that is it's easy to flash back to the stock map and nothing is permanent.
    2022 RT Sea To Sky
    Quote Originally Posted by Praireroads View Post
    I'm either blind, or that info was in one of the sections of the site that looks like it should have info but was blank when I looked at it, or MF doesn't post it. Anyway I didn't find any prices on the MF site when I looked last night which is why posted the question.
    SoFlo
    Has anyone done a topic that compares a Monster reflash vs Dynojet setup. No true plans to make a change, but others have asked, and sometimes you never know. Maybe I will decide we need to make a change.
    Very Active Member wmh9680's Avatar
    Nov 2015
    Tinley Park, Il
    I have the stage one and Monster just told me it's $150 to add the stage 2. I'm gonna do it soon. Mike
    2014 RT Limited Matte Silver, Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars,
    Will it ever stop--NO
    Aug 2019
    Stoughton, WI
    The biggest drawback with the PV3 is lack of tuners who have the capability to put a Spyder on a dyno to do custom tunes. The PV3 device itself has so much tuning capability. In the two wheel world, the biggest advantage of the Power Vision is getting a custom tune for your specific machine. A custom tune for specific builds is better than a broad brush stroke of maps/flashes made on a specific machine to work on all models. Heck, the ECU flashes are for multiple years/models. Not all machines are created equal. Sure, they're better than nothing, and in most cases work very well. I have used both, but in the end, I prefer the non permanent route. Over time, the map base for the PV3 will improve.
    2022 RT Sea To Sky
    Mar 2015
    forrest above Reno, Nv
    As one of the owners who has taken the leap to the ECU flash-------- it's worth every cent. There is of course the huge smile on your face causing the right wrist to twist just a bit further.
    Lew L
    2014 RTS , Circuit Yellow
    Northern Kalifornia
    I've not spoken to Wick-It personally, however from comments by those on this site who have, I understand that your flash is done according to a stock set up, or, whatever improvements you've made to your machine. Air filter/air intake, cat still installed/cat delete, muffler stock/straight pipe, and so on. Give Wick-It a call, I'm sure all your questions would be answered, that's their business. As for a "Monster reflash vs Dynojet setup," Google it. There are a number of other motorcycle sites who's members have discussed that very issue in great detail. If you search ECU/flash on this site it'll keep you occupied all day and half the night. Good luck and let us know what you decide.
