Results 1 to 21 of 21
    Jul 2013
    SF
    Default Ram intake system by Treal performance
    Has anyone bought or thought about getting the Ram Air Intake System by Treal Performance?
    Can anyone tell me if I was to get it will it mess anything up? Can I just add that without doing anything else to it? Right now I have a two brothers exhaust. I only want to do these two things and that’s it. I’m not experienced with the performance side but I like the way it looks and sounds.
    SoFlo
    Quote Originally Posted by Jsalientes3 View Post
    If you like how it sounds and looks, that is 99.9% of the reason to buy it. Ram air designs, unless accurately validated, typically do little to nothing in regards to increased performance. Some designs for cars and trucks see gains, but most remain about equal to stock.
    I saw a silly video showing a Ryker up on two wheels and such. If the increased power alone did that, a dyno chart is worthwhile.
    Jul 2013
    SF
    Yes I’m more for the looks and sound at this point. So can I put the intake on with my two brothers exhaust without doing anything else to it? Meaning not tuning, no dyno, or any issues, etc?
    I just want these two things without doing any more to it. Because I’ve heard I need to get a dyno, headers, etc. which I know nothing about that stuff. I just want the looks and sound with no issues.
    Active Member wingit3611's Avatar
    Dec 2016
    Louisville, KY 40214
    According to old Dodge theroy longer input tube gives more low rpm torque. Doubt it it measurable.
    Can Am 2013 RTL SE5
    SoFlo
    That is a question for the manufacturer of the intake, and I would ensure I got a clear detailed answer in writing. If it does not work, that way you might get a refund.
    I answered this question on the other Thread on this subject by Batmobile-F3 …. read posts #3 & #11 ….. On my 1330 I added two computer fans …. one before the air filter and one after the filter ….. These fans move a lot more air than a scoop and large intake …. But, I did this before figuring out that the BRP computers will compensate for this increase in Air. …… But these fans didn't decrease the power in the engine - ie. didn't hurt anything …… good luck …. Mike
    Jul 2013
    SF
    Ok thank you
    Dec 2016
    I doubt the computer fans boosted the manifold pressure. Did you measure the manifold boost?
    Can Am 2013 RTL SE5
    Aug 2007
    Greeneville, TN
    So, in other words, a poor man's blower then!
    Quote Originally Posted by wingit3611 View Post
    #1- ……… #2- No I didn't measure it ….because of #1...…… Mike
    That was my original thinking ( to some extent ) ….. however after I figured out that the way BRP has the computers set up, Today's technology cancels pretty much All the things you could do to boost power ….. It doesn't hurt to attempt things as long as it doesn't hurt anything...…………… Mike
    Aug 2007
    Greeneville, TN
    I am not sure that it's so much that the computer works so much to cancel this kind of mod as it is to compensate. It's not the same thing. In other words. If you flow more air past the MAF sensor, the computer will add more fuel to compensate. Just like the computer will compensate for a colder, denser air mass. Or hotter, less dense air mass, etc.
    Who knows? You may have done more good than you think! At any rate, mods can be fun. And like you say, if it doesn't hurt anything. You're still good go to!
    Aug 2007
    Greeneville, TN
    I am not sure that it's so much that the computer works to cancel this kind of mod as it is to compensate for the difference it makes. These are not the same thing. In other words. If you flow more air past the MAF sensor, the computer will add more fuel to compensate. Just like the computer will compensate for a colder, denser air mass. Or hotter, less dense air mass, etc.
    After all... Can you have TOO MUCH HP?!
    Member Knight's Avatar
    Aug 2019
    Blue Lake, CA
    In case anyone was wondering like I was, here's what this intake looks like:
    Video from Treal's website:
    Finally, a link to their product page:
    https://www.trealperformance.com/utv...-intake-system
    Personally, I think it looks goofy. But to each their own. Definitely an aggressive look.
    2019 F3 , Black
    Jun 2011
    Alamogordo, NM
    My educated, experienced..........opinion is don't waste your hard earned $$$ is don't do it....unless you are one of those that wear your Base Ball cap backwards because you think that it makes you Cool Man.....
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    Active Member Greven's Avatar
    Oct 2019
    Sweden
    When a company makes a lot of claims for increased power, torque, speed, and even engine temperatures(lol), but provide ZERO b2b dyno tests etc, that is a HUGE warning flag.
    Dont get me wrong, I am not against tuning and hot roddin'. Most modifications, especially those that increase engine performance, will also have a negative effect on durability, but at least it should be clear what what you get, so you can value the risk vs reward.
    A "desktop-tune", for example just increased RPM limit, agressive timing, adjusted fuel tables, etc could make for a quick demise of an engine.
    I am not saying that is the case here, I am just saying its a risk, and the way they advertise it makes my engine spider sense tingle big time.
    As far as the intake goes, the "RAM" effect looks like it might very well be worse than the stock scoops. And as with any "sport" aftermarket filters one should think both once and twice regarding the risks, since you for example dont know what the filtration efficiency is compared to stock OEM.
    The looks and intake sound on the other hand, thats a personal preference if you like it or not
    Since Im at it, the modification mentioned with computer fans, very creative but wont add any measurable power. They are not adding significant boost, and with no boost the air mass flow will be the same (unless you have a very agressive cam with a lot of overlap). Not meant as critizism, just input!
    Quote Originally Posted by Greven View Post
    ALL input is a good thing ………. But in my Post on this, my opinion was …. THE BRP COMPUTER WOULD VERY LIKELY CANCEL ANY ATTEMPTED BENEFIT ……… Just keeping it Real ……....…………...Mike
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    I posted this in another thread about the same thing. This set-up is really just a CAI (Cold Air Intake) for the Ryker and where it may benefit cars by cooling the intake charge going into the combustion chamber, I doubt it really does much for the Ryker since the engine is exposed to the environment and the intake is already taking in cold air from the side of the Ryker.
    May 2019
    Carlton
    Unless you remap your ecu after adding your mods, then as stated above your ecu will just try make it run at pre programed factory settings... it will make little or no difference other than use more fuel and prob run worse. Back in the day before ecu's you could chuck a filter on and rejet your carbs etc.. but not now without a computer to map stuff in or out im.
    Jun 2011
    Alamogordo, NM
    Quote Originally Posted by Curlytops View Post
    Not quiet true. The ECU easily can adjust to the minimum differences differences these most minor mods do. As soon you remap your ECU you will most likely void your factory warranty. The Ram Air set up in this thread is for looks only.
    Dean O
    Gran Pa Hoon
    Alamogordo, NM
    '20 Spyder F3 L
    Sep 2017
    Durham,Maine
    Put a Turbo and a programmer with it ad then you would have a package worth having!!! just cold intake not so much! My 2 cents!!
    2012 RTL , Pearl
