Results 1 to 15 of 15
Thread: 2020 f3l
    Aug 2018
    Piperton, TN
    Default 2020 f3l
    I heard a rumor that the top case on a F3 Limited could easily be removed the same way as the new 2020 RT. Does anyone know if this is true?
    Jan 2019
    Euclid, Ohio
    Very True. There's a video on You Tube. You'll need a rear fender if you do not have one already. Takes about 5 minutes to remove. BTW I have a 2016 F3T with an added BRP topcase.
    Mar 2017
    Jun 2016
    Harrington, Australia
    Yeah, but that’s the 2017, Rattlebars, which is still a pain to get off. Ollicat is asking about the new 2020, and whether it is as simple as the “couple of wires and a single fastener” like on the new RT.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    I see that they offer the LinQ system for 2020 RT's but does not seem to be available for the F3 system.
    Page 47 of the new 2020 catalog, in the RT section. No such, that I find, in the F3 section.
    Thanks to JP58: Page 19 of catalog...under specs....shows LinQ Compatible Top Case.
    Sep 2009
    La Valle, WI
    Look at can am website under F3L then under specification. It shows it has the linq system.
    2018 F3 Limited , Oxford Blue
    Feb 2020
    Arizona
    For earlier F3 limited you could remove the top case and install a "tail cover".... I can't for my life find any information on tail coves for the 2020's..... anyone know if this is an option and if so where I can get part information? Called a dealer today and he said its a "mono seat cowl" but that doesn't sound right to me... although maybe it is
    formerly pman2011 YIRYDE's Avatar
    Sep 2012
    Northern Virginia
    Quote Originally Posted by AzBTO View Post
    See page 47 of the 2020 Accessory Catalog, https://can-am.brp.com/content/dam/c...e-us-final.pdf
    You dealer sounds clueless on the 2020 RT.
    [B]
    2018 Intense Red F3T (See About Me under My Profile for mods)
    2010 Timeless Black RT-622 Trailer
    2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
    2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    Quote Originally Posted by YIRYDE View Post
    Your link is for the 2020 RT. AzBTO is talking about the F3 Limited, not the 2020 RT. You are in the F3 forum.
    2020 RT Limited , Petrol Blue
    Apr 2019
    PA
    I am waiting to see myself. 2 weeks ago I asked the same question. My dealer said no it is not like the 2020Rt but others on here said it is. My dealer said that if there are passenger arm rests they need to be unbolted also. I watched all the videos and can’t see a single F3 that removes the seat and how the arm rests are attached. My dealer only has the Rt’s on display not the F3. Does anyone actually have a 2020 F3 or are they late coming because of the new RT’s?
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    This may help explain the difference between 2020 F3Ltd and previous models
    Not that many changes
    https://youtu.be/3I1EHbTA7r8
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
    Sep 2012
    Northern Virginia
    Quote Originally Posted by Michaelscs View Post
    My mistake, I was thinking 2020 RT considering there is so much talk on the forum for the 2020 RT. If I find anything I will post it.
    [B]
    Feb 2020
    Arizona
    I'm "guessing" that since the new F3T and the F3 Limited both support the Linq system that you could get an F3-T rear cover and use it on the F3 Limited with the case removed but wouldn't bet my paycheck on it.... I do like the idea though of having a little bit shorter bike (top case removed) and only use when i need it... but of course things aren't that simple. The new RT looks nice but crap that's more than my car cost....
    Very Active Member YPILOT's Avatar
    Aug 2009
    Johnson City,Tennessee
    Quote Originally Posted by ollicat View Post
    Here is a list of features that list "LinQ compatible top case"
    Also the cargo accessories for the F3-T list the RT top case as an option.
    I'm still waiting to see the F3-L as well, however I test rode the RT-L
    today and the top case lid has a much better hinge than the 2019 F3-L.
    Although there is no mention of the fender cover for the F3-L when you want
    to remove the top case but it should be in the parts catalogue for the F3-T.
    It is also described on page 29 in the catalogue mentioned in post # 8
    SPYDER F3 LIMITED
    Key Features
    Rotax 1330 ACE in-line 3-cylinder engine
    Semi-Automatic 6-speed transmission with reverse function
    Vehicle Stability System
    Large 7.8” wide LCD color display with BRP Connect™, allowing the integration of vehicle-optimized smartphone apps
    Custom riding position with UFit System
    Driving Mode: Eco Mode
    BRP Audio Premium 6-speaker sound system
    Cruise Control
    Calibrated for towing a Can-Am trailer
    Integrated hard side luggage
    LinQ compatible top case with integrated passenger backrest for a total of 36.5 gallons (138 L) of vehicle cargo capacity
    Audio control keypad
    Convenient console with integrated windshield, mirrors and glove box with USB port
    Automatic self-levelling rear air suspension
    Rider and passenger heated grips
    Rider and passenger footboards
    Parts and trims available in Chrome or Dark Editions
    "Stupid is as Stupid does"
    Don't Drink and Drive or Ryde!
    Each Day is a Gift
    Aug 2018
    Piperton, TN
    Interesting that the RT top case is listed as an accessory for the F3T.
    Also, I totally agree that they need to show the fender cover as an accessory for the F3L
