Results 1 to 7 of 7
    Aug 2019
    Texas
    Default Dashcam for Spyder?
    I'm rather new to the spyder world as I've just picked up my F3 Ltd., so please accept my apology for any ignorance...
    My car is equipped with two dashcams, front and back, which continuously record in a loop.
    I'm looking for the same option for the spyder, but with a secure mount so that can't be stolen (easily).
    Can anyone recommend either a single direction or dual direction kit?
    There's a lot of bad drivers out there and video is priceless when an accident occurs.
    Much appreciated.
    Apr 2019
    Clinton, MS
    Take a look at the iNNOVV K2 system. Installed on my 2019 RTL and like it.
    https://www.innovv.com/innovv-k2
    Jun 2011
    Kerrville, Texas, USA
    EdMat -- did you do the install yourself? Any chance you could post a picture of where you mounted it (front and back)? I looked at the system and like what they've done with the setup, but don't know the first thing about the install process. Thanks.
    Regards,
    Bret
    2017 RT-S Orbital Blue
    BajaRon Anti-Sway Bar
    SpyderPops LED Bumpskid, Spyclops II LED, Full View Turn Signals & Belt Guard
    Sena 20S Bluetooth Headsets
    Brake Free Helmet Light
    FOBO Bike for Trike
    Rugged Geek RG1000 Safety Plus Jump Starter/Air Compressor
    Lamonster RAM mount/Techmount TechGripper
    Drink2Go Cup Holders
    UltraGard Half Cover
    2017 RT-S , Orbital Blue
    Active Member scarecrow's Avatar
    Sep 2013
    largo, florida
    I'm using IBeam, go to www.haviic.com and look at blog.20191118_154406 (2).jpg[ATTACH=CONFIG]20191118_154712 (2).jpg20191118_154631 (2).jpg
    2014 RTS , Cognac
    Apr 2019
    Clinton, MS
    Quote Originally Posted by bhern View Post
    Used the 90 degree mount it came with on the rear. Made a custom mount for the front. Mounted the unit under the seaat.
    Jan 2019
    Hunter Valley NSW Australia
    The only suggestion I can throw in is check the footage from a few. If you cant make out the Number/License plate in the footage look for one that does. I've seen the Innov and it appears to be clear enough for most situations.
    2017 RTL , White
    Nov 2016
    Upstate NY
    I have an hp f310 mounted under my left mirror with power coming from frunk dc outlet. I also use the same dashcam in all my vehicles and have never had any issues or failures. It also records speed and gps location.
    2021 Sea to Sky RT , Highland green
