Results 1 to 18 of 18
    Oct 2013
    rome new york
    Default Removing sticker glue
    Just got my 2018 F3 Limited from Imotorsports
    Apparently they had a sticker on dash and windshield and left the residue. Being they were to lazy to clean it off.
    I am looking for ideas how to remove it without hurting the windshield or plastic dash .
    TIA
    Active Member VitoNam's Avatar
    Nov 2018
    NW Minnesota
    Good old WD-40 will work well and it's something we all, most likely, have sitting around the shop so nothing special is needed to be bought.
    As with all things dealing with plastic, especially clear plastic, test an inconspicuous area first. After the goo is removed, wash area with soapy water.
    Jul 2018
    Fountain Hills,AZ
    +1 WD-40 I work at a hardware store recommend all the time..
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    WD-40 or Goo Gone
    2022 RT Limited , Silver w/ Black and Purple accents
    Nov 2012
    North Las Vegas, NV
    Goo Gone.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Sep 2014
    USA
    GOO Gone as mentioned
    NorCal - Northbay
    And for an all natural option.... Peanut butter! Yup, it really does work. And NO, NOT the crunchy kind!
    Chuck
    INDIANA, USA
    Default Peanut Butter
    Yes, I have used the smooth peanut butter to clean areas.
    Be careful and test a small section first.....
    ENJOY YOUR LIFE WITH A SPYDER
    Member JTYALOR's Avatar
    May 2019
    Dallas Tx
    goo be gone wd 40 tooth paste if it is real bad 3m adhesive remover
    2019 RT , lamonster ext brake pedal GRAY
    Jun 2014
    ny
    rubbing alcohol
    No one solvent will work on all adhesives. I've used 90%+ alcohol on some that mineral spirits wouldn't touch, and vice versa. Acetone will often work but in some cases it can etch paint. White gas (Coleman camp fuel) sometimes works great, and sometimes not! You just have to experiment to find the best one.
    SoFlo
    You stated there is residue on the acrylic plastic windscreen and on the instrument panel overlay.
    Regarding the windscreen, anything more intense than isopropyl alcohol may ruin the ability to see through it. WD is probably ok, but then you need to remove the oily residue.
    If it were me, on the windscreen, I would try a new high quality microfibre cloth and Lemon Pledge or similar high quality automotive wax.
    Not exactly sure about how bad or where on the instrument panel overlay the issue is. You might try the same technique first, going with WD next.
    Downside in dealing with the windscreen, the wrong chemical will craze the plastic, and sadly, most chemicals are not good on acrylics.
    Vermont
    I would try Goo Gone.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    SoFlo
    I checked the Goo Gone website, they defer using it on plexiglass and leave it up to the plexiglass manufacturer.
    Considering the cost of a new windscreen, Goo Gone would not be used by me on plexiglass.
    But entirely your call.
    Consider this, if the windscreen is destroyed, with so many here suggesting Goo Gone, each of them can chip in $20 towards a replacement and the test is complete.
    Isn't plexiglass polycarbonate and thus not the same as acrylic? The windscreen is acrylic, isn't it? Just asking since Goo Gone may be OK on the windscreen.
    SoFlo
    Plexiglass is acrylic, Lexan is polycarbonate. An F4 windscreen is polycarbonate, stock is acrylic.
    Active Member Raknid's Avatar
    Central NJ
    I am not sure that I would use GooGone on a clear plastic windshield or dash. It is pretty strong. I would probably try WD 40 first or maybe Plexus. Let it soak into the adhesive a bit.
    2012 RT-SE5
    May 2013
    Apex, N.C.
    I was going to say WD-40 or Goo Gone, as I have used it on all my bikes.
    But with the guys suggesting peanut butter, I would have to give that a try just to see if it works. A nice natural alternative to remove stickers would be really nice. One key thing to do is let it sit in the sun and warm up as much as possible. That should make either one of the above work better.
