Results 1 to 8 of 8
    Mar 2019
    lakewood ranch fl
    Default Akrapovic carbon fiber
    want to put an Akrapovic on my 2019 f3 limited black . any one have found or constructed a carbon fiber heat shield , or any ideas on how to keep the black look .
    is there a carbon fiber wrap that can stand the heat ? any input would be great. or do they make an Akrapovic in Carbon fiber for the ltd . I know the have one for
    the f3 3 , could just paint it HI heat black , thoughts.
    Thanks
    SoFlo
    Doubtful you will find a wrap capable of repeated high temps.
    If you replicate the oem item in carbon, choose wisely on the resin system, most will show yellowing at temps above 180f.
    Mar 2019
    lakewood ranch fl
    Thanks for the info . think I might try to reuse the stock heat shield. or just leave the Akrapovic as is .
    Apr 2019
    Florida
    Quote Originally Posted by spyderbear View Post
    I think it looks good with the Akrapovic as is.
    2019 F3 Limited , Big Bike Parts full size pedal Black Metallic
    Mar 2019
    lakewood ranch fl
    How do you like it , sound , did you leave baffled in ?
    Greenville Tx
    I have a RLS Exaust. Ricky sprays a coating that drops the temp by 400 degrees. He can even spray the Cat delete. Not as pricy as a akrapovic either. Also the best sounding Exaust out there IMHO.
    2017 F3 Limited
    Apr 2019
    Florida
    I like it. I found it online at a Can Am dealer that had a few that he was selling at 1/2 price. It was new in the box, yet it came without the baffles. I also have the RLS cat delete, and together I think it sounds pretty good. Louder than stock, but no annoying drone when cruising at highway speeds. I ran it without the cat delete for a few thousand miles, and honestly, adding the RLS cat delete without it's baffle, did not increased the volume all that much.
    Mar 2019
    lakewood ranch fl
    tx your bike looks great . you my be right about leaving it alone . But I just can't LOL
