Handlebar Grip Vibration
Hi All.....I just bought an 08 Spyder and I'm new to this forum as well. So far I love 'em both. One problem that I did notice is that my hands get numb from the vibration after riding for awhile. I see that Can-Am has made anti-vibration grip inserts, so I'm assuming that I'm not the only one with this issue. What have other riders used? Any luck with the Can-Am grips? Has anyone tried the Kuryakyn Iso-Grips? I like the Kury's by I have small hands and find that the grip feels too large for the hands. Has anyone found a "dress up" grip with a smaller dia like the OEM size? Thanks again for everyones input.
Blazing Member
I had this same problem and it all went away with the Kuryakyn ISO Grips. I have small hands as well and find that these grips fit perfect since i don't have to close my hands and helps to relax the grip some.
Some have been happy with the anti vibe ends and other have gone another route of using a throttlemeister weighted to do a throttle lock as well as weight the bars some to get rid of vibration.
Happy SE5 Owner!!!
Silver/Black SE5 - Trunk Liner, 1" riser, 12v, Kuryakyn ISO Grips, 5" Kewlmetal Pullback Bars, Kewlmetal Console, Zumo 450, Ipod, Kewlmetal Highway brackets with Wing pegs, Triple Play, Wizard Light LED's, Corbin front/rear saddle with Backrest, Nelson Rigg CL950 Saddlebags with CL800 Tote Bag, CalSci Medium Windshield.
Some things that help:
BB's in handlebars or get a Bar Snake.
Grip Puppys that go over your stock grips.
Handlebar risers from NMN.
Bar end weights.
Loosen your grip.
For me the very best thing I did was to install a Throttlemeister. The TM allows you to 'lock' your throttle and remove your hand from the bar. It also has end weights to help with vibration. Before the TM I could only ride for 30 minutes - now I can go all day!
welcome
RT-S PE#0174
welcome I had the same problem!!! I posted a thread on July 13th, Look up the thread "couldn't feel my fingers". In the meantime, I have learned to relax and not grip them too hard. Flex and wiggle your fingers while driving. At stop lights I would rub them on my legs. I also bought another set of gloves with gel palm pads, that was a big improvement.
Being 5'5', I lean forward too much. That causes me to over extend my arms which restricts blood flow to my hands. Try bending your elbows, I scooted forward in my seat.
I have a 4" inch riser on order, waiting for them still to come in. I ordered the Kuryakyn Iso grips last night. My husband has a set on his bike, big improvement.
You came to an excellent site!!! Ryders are so helpful and nice, great info, I have learned so much here!!!
welcome enjoy your ride!!!!
welcomewelcome
put BB's in handlbars well help with vibration have to plug left handlebar so bbs stat read post on ho to do in shop talk VT228 Don and welcome to the family
welcome
PE #2735
RUBBER SIDE DOWN SHINY SIDE UP!!!!!!!!!!
Never ride faster than your Angel can fly...
Do you have risers? I find some of the numbness is due to the stock bars being too low, causing a lot of my upper body weight to transfer to the palms of my hands. I'll be adding risers on my next dealer visit.
I found some gloves that have more palm padding and that has helped some. I also installed the BRP anti-vibe kit and it lessened vibration, but others have posted alternate ways to add weight to the bars.
welcome
Risers will help. I personally have the billet anti-vibe kit and it works great for me.
Alignment Specialist
Throttlemeister nice as it has weight and you can rest your hand, at times...
Bone Crusher
If you work to make money, you'll never be happy, as there's never enough money...if you work to take good care of people, the money will always be there....Sean O'Connell, 1999
