Results 1 to 14 of 14
    SpyderLovers Sponsor merlot's Avatar
    May 2015
    Tasmania
    Default Magic Mirrors Fix for loose mirrors on Ltd and T
    its feral weather here atm so my attentions have turned to my new ride
    ive polished it so much that im in fear of rubbing it away
    my thoughts went to the terrible loose mirrors on the bike
    nothing else for it but to remove the complete mirror
    the inner frame comes off like the RT with 2 posts at the bottom,and a sliding post at the top
    it has the same 2wire set up also for gripping the post
    on inspection,the wires were not too bad....if opened up would only require bending back,but there was no easy fix for me
    so i got out the O ring box and found a size which would fit onto the pins
    i fitted one to each post(the top post was a little smalled diameter) but i stayed with the same size Orings for the 3 posts
    i then refitted the mirror frame and result was magical(i had to use that word)
    then i copied Shaun Smoakes idea and fitted an Oring to the 2 plastic posts(one top and one bottom).....these Orings were smaller
    put it all back together (i used a dab of grease on the 3 nasty wedges which hold the shell on...made them go on so easy)
    these mirrors are now Cadilllac...they move slightly but the movement feels like the whole mirror is rubber mounted..a bit like engine mounts
    it turned out so well that i decided to do the other side too,which wasnt quite so bad
    i may do a video if this weather keeps up
    before fitting rubbers
    rubbers fitted BS 010
    Shawn Smoakes fix BS 008
    if anyone wants more detail then happy to provide
    Parts required: 3off BS 010 Orings for 3 pins (each mirror so 6 in total)
    2off BS 008 Orings for top and botton plastic pegs (each mirror so 4 in total)
    so 10 Orings all up...................prob cost $2.00
    russ
    Mar 2017
    Interesting. I did the Smoaks oring on the pins, but never did take a look at the studs. Will give that a try during the current Arctic Breeze in SC.
    Headed to Harbor Freight today.
    BF orings >click here<
    Feb 2019
    Portland, Oregon
    Thanks Merlot....I am a big fan of DYI work arounds. i'll be making a trip the Harbor Freight too.
    Active Member MagYukon's Avatar
    Sherbrooke, Qc
    HI,
    very interesting information.
    How do you remove those mirrors exactly ?
    You just have to slide them ?
    I did tried, but was afraid to break something.
    Thanks !
    X-Grip Ram Mount Phone Holder, Lamonster Fog and driving lights, BRP Heated grip, Home made rear rack + Shad SH58X top case, BRP belt tensioner
    2016 F3T , Red
    May 2015
    Tasmania
    the mirror is in 3 parts
    first remove the shell....it pulls off
    second undo the screw(torks bit) this releases the glass
    release the blinker wire coupling underneath
    third remove the mirror frame........watch the vids on RT mirror removal...Pierre made a really good one...it is similar design
    it takes a bit of force so better to know exactly what you are doing....as you say dont want to damage anything
    https://www.youtube.com/watch?v=NReoHtqs70Q
    russ
    Dec 2015
    Oakley Utah
    Oh you devil! Tasmanian, right? Great way to snug up loose mirrors.
    2014 RTL Platinum
    May 2015
    Tasmania
    russ
    May 2015
    Tasmania
    Utah Pete
    didnt i sell you a set of Magic Mirrors back in the day?
    you were one of the first buyers as i remember
    so what are you doing on F3 site? lol
    i think this Oring fix would prob work on RT"s also
    but its a different animal.......the RT mirror needs to be removed for every service operation whereas the F3 just needs to stop shaking
    russ
    pres ride
    2014 RT-S
    bike is WIP
    bike has endured elect spike (was jump started incorrectly)
    still a WIP but bike is now running and registered....swapped out 5 modules mostly sourced from Canadian wrecker
    Active Member Doug's Avatar
    Jul 2013
    Brights Grove, Ontario, Canada
    Just to confirm for my benefit is this the solution to the mirror covers especially the left one from vibrating and falling off the 2019 F3T AND LTD
    2017 F3-S , circuit yellow
    May 2015
    Tasmania
    no doug...........not for the outer shell
    my left mirror was really loose so i addressed the problem from the pins perspective,which attach the mirror to the bike
    russ
    pres ride
    2014 RT-S
    bike is WIP
    Mar 2017
    I had a problem with the shell falling off on a dirt road with a horrendous rut. I heard it hit but did not know what made the noise until I stopped at my destination And looked at the mirror! The shell was gone! I figured I'd never find it so I rode home and went to order one finding the price to be an astronomical $120!!! So, Next day I made the 2 hour ride to find the dirt road again and searched.... found it in the weeds and it had a scuff mark on the underside which is not visible when mounted. I don't worry about them coming off anymore because I mounted Baker "hand" wings which comes with a screw that secures the shell to the mirror body.
    In looking at the magic mirror in Lamonster's video, I wonder of one can get the actual Magic mirror kit and put it on Backward with the magnets on the mirror and the disks on the bike. Wonder.
    Quote Originally Posted by Rattlebars View Post
    Magnet size was the major issue when we looked a while ago - the RT mirrors & pins have wider spacings so there's more 'real estate' for the magnets to fit into, and the Magic magnets were simply too big for the F3L & T's.... But maybe you could use a smaller magnet, if you can source one small enough but still strong enough to work properly??!
    May 2015
    Tasmania
    what about a magnet to hold the shell on?.....just need to araldite some sheet metal inside the shell
    rattlebars has got that sorted but i inherited a broken clip receiver and araldite has sort of helped that,but not completely happy
    if you fit the orings youll forget all about magnets
    pres ride
    2014 RT-S
    bike is WIP
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    I have used a Zip (Cable tie) to secure the outer cover to the mirror housing on my F3T
    See
    https://www.spyderlovers.com/forums/...-temporary-Fix
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
