convert F3-S to F3-T?
It seems the biggest difference is the saddlebags and windscreen. Is it possible to add CanAm saddlebags (not 3rd party bags) to an F3-S?
??? … Doesn't the " T " also have a radio / speakers etc. ???? ……… Mike
Can Am sells Shad bags that will fit your F3-S
They each hold a fullface helmet.
The F3-T has a different swing arm so no just bags is not true. You can use a Can Am trailer hitch.
Why?
Find a dealer that has a F3-T and work out a trade!
Anything converted looks like it was converted. There are a lot of differences that are to recognize!!!
A member here has converted the front of his F3 to that of the F3T/F3L and it looks factory. I don’t think that there is anyway of adding the factory cases to yours though.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
An interesting project if you can work it. In most cases, it will generally cost way more by adding "parts" to get a certain look, compared to OEM.
Others are also right when they say the final results can vary.
In the beginning...(now there's an interesting statement )...I changed our 2008 and 2009 RS/GS into RT's....before they came out in 2010. I ended up buying a 2010 Premier and traded in the 08. I lost my shirt on the trade, those $6K of accessories were worth zilch.
It was a fun ride while I had it though. Worked for me.
Yup ... Radio/speakers you can't hear above 65mph. A helmet with BT audio a much better option...
2022 RT Sea To Sky
The radio is actually an option on the F3T. You can get it without the radio. I have the radio on my 2016, and I can hear it very well at any speed.
Considering the postage stamp-sized saddlebags on our F3T, I'd think more about seeing if I could add the F3T front end body panels to the F3S and stick with the Shad bags that work with the S.
ABQ is correct, you would need to change the swing arm. I personally like the Shad bags better than the T or L. They have more room, plus it’s a lot less Tupperware on the rear end & cleaner looking. Adding the front console upper half to become a T or L isn’t that hard or expensive if you look at the cost between the models.
That’s the way to go grumpy!
I really like your top case setup JS3535. I looked for that Formed Support, and Can-Am no longer makes it. I amy just have to make my own.
Cheers
Bill
Cheers
Bill
That's what I did. It turned out great using aluminum I purchased from McMaster Carr.
2021 Sea To Sky, 2020 RTL
but our benefits don't?
I have health issues which I must ameliorate by air control. I have an F4 tall shield (no vent) + F4 hand wings + Slingshot side extenders + Moparty xcreen clone up top. Until I added the Moparty that was true. Now, tho, I can listen at any speed.
Full details ON MY PAGE >click here<
Thanks for the replies. Sounds like I should just start with where I want to end up - with an F3-T.
Bill...
The S and T have a different chassis rear of the fuel tank. Would not be easy to mount the T saddle bags to the S chassis without chassis modifications. Others have address the swing arm difference.
Regards,
Don
Did you do the conversion work yourself? That looks cool!
Joshua
2012 Victory Vision
2016 Spyder F3S
2019 Spyder RT Limited
Yes. Wasn’t really that hard just time consuming & $2500.
Sling mods is coming out with a new luggage rack, top case and saddle bags for the Ryker in early 2020 for around $500. You might take a look at that and see if you think it could be fitted to an F3.
I just mounted shad 36liter "OEM manufacturer" you have to buy mounts and bags separately to get best price
The Shad bags are larger. Do not envy the F3T/L panniers as they are pretty minimal. They do look good...
2018 Can Am Spyder F3L, 1995 BMW R1100R, 1988 Suzuki GS250, 2019 Ryker 600 (Wife's)
The one advantage is that you can still get an F3 with a manual shift.
I'm getting the 2020 RTL with the paddle shifter. It seems sacrilegious, but I guess no more than getting a three wheeler to begin with.
I thought of converting the manual shift F3 to a touring rig.
Believe me, I thought hard about it.
IBA #47122
2020 RT Limited Asphalt Grey
AFAIK - The vast majority do. But my 2016-F3-T came without radio/speakers/antenna, which was just fine with me.
Bert
