Results 1 to 3 of 3
    Jun 2017
    Arlington, Az
    Default Codes C0040 & C006C with Limp home mode
    Good day all, my 2014 RTS is showing fault code C0040 & C006C and goes into limp home mode. I also do not have brake lights but I do have tail lights. I have removed the battery, cleaned it up and when I reinstalled it I left off the aftermarket connections. I checked all the fuses and found that the 5A fuse in position 6 (DC plucs VKEY) on the right fuse box was blown and I replaced it. This did not help to fix any of the problems.
    I would appreciate any suggestions that you may have.
    Jun 2015
    Hampton Roads, VA
    Did you figure this out? I have the exact issue now! Happened after the wife stopped hard doing about 45mph. Now, just pushing the brake pedal triggers it sitting idle...
    Dec 2013
    Similar discussion and its resolution here:
    https://www.spyderlovers.com/forums/...040-amp-C006C&
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
Tags for this Thread
