Results 1 to 4 of 4
    Mar 2019
    Fla/NJ
    Default RH fuse block help
    2015 f3 Wanting to hook up to accessory conn under rear seat. Found no power there. Checked continuity from accessory outlet under seat to fuse block that's good. Fuse is good but I have no power into the fuse. Tried with ignition on still no power to fuse.
    Any Ideas??
    Feb 2019
    Portland, Oregon
    Those customer connections (or whatever BRP calls them) are energized when the key is on, so I have found. But learning here about the bike's fussy electronics, I added a fuse block for accessories just above the battery. It is energized only when the ignition is on via a relay activated by the nearby customer connection. Now accessories are independent of the bike's systems. Here's where I got it from....
    https://www.banggood.com/DC12V24V32V...r_warehouse=CN
    Active Member Kmort44's Avatar
    Jul 2011
    South Bend IN.
    My F3-T accessories circuits are only energized with the bike running.
    ​KMORT44
    Mar 2019
    Fla/NJ
    Thanks for the help. Seems bike needs to be running. So im good to go.
