IBA #47122
2020 RT Limited Asphalt Grey
Originally Posted by IdahoMtnSpyder
Think about it for a minute and you'll see why it's not dumb! When the meter is recording mileage you push the "Pause" button to pause the recording. Then when you want it to start recording again you push "Resume". Now it makes sense, right? They're not status indicators but rather action indicators!
The problem is, when in "resume", it still doesn't work.
My wife’s does the same 2015 RTSpecial
Originally Posted by ARtraveler
This happens to many.
When button shows "pause" the meter is on.
When button shows "resume" the meter is off.
Finally was able to get out and see if the above info was correct. IT IS!! Is the temperature so cold in Canada that it freezes the brains of the Can Am engineers. "Pause" means go, and "Resume" means stop. Did the Mad Hatter make that determination?
As I said above they are action indicators, not status indicators. If "Pause" display meant the odometer is stopped then what should the label be to make it clear you push it to resume odometer reading? Isn't that how your car cruise control is labeled? "Resume" there means reactivate CC. Now if the buttons were labeled "Paused" and "On" or "Running" that would be more intuitive, but then the display would need labels to make clear what to do to stop and start odometer recording.
At least that's the way I see it. Makes perfectly good sense to me why the display shows what it does!
The problem is, as indicated above, the response of the system is reversed. In pause, instead of being stopped (or inactive), it goes active and starts registering mileage. In resume, which should indicate reactivation, it is stopped and does not register. Unfortunately, in the Owners Manual, I have not been able to find anywhere in there with a definition of each response.
Another way to look at it. When you go to make any changes, such as pause, push the button pause and it will do it. If you want it to resume just push the button that says resume, and it will do it.
Usully, you just have to do this once. Most of my adjustments are to clear the number in register A when I fill the tank, and to clear the number in register B when the trip count is over.
But, I still agree with everybody I would like to see it the other way. I don't like reasoning sdrawkcab.
Actually, it is the reverse of that. It came to me last night. The indicator shows what is CURRENTLY in effect. If showing pause, it is in pause and not registering. When you push pause, it does not go into pause (it is already in pause), but goes into resume and starts registering and the indicator shows resume, what it is in now. The indicator shows what is happening now, not what will happen if you activate the response.
Why, yes. Yes, I did...
~Sandee~.
~Sandee~
2016 RT-L (Purchased used in February 2018)
RT Dash Mount (from JT's Spyder Store)
Kuryakin Trident Highway Pegs
Hopnel Pouch
Magic Mirrors
Spyderpops Foam Handgrips
Iron Butt #35273
Girls on Spyders #2779
On mine press it and it selects the trip meter or the total mileage. Press it again and it moves to the next trip meter without re-setting. If you want to re-set the trip meter to zero, press and hold the button while it is on the meter you want to re-set. Pulling the button to the left operates all the mileage functions. Pushing the button to the right works the clock, RPM, fuel mileage, external temp, and settings.
the "up button" puts it in pause, down and hold slightly, will reset
Do any others use the trip meters the way I do. Trip A is my current annual mileage, I reset it at the beginning of every riding year. Trip B is my current oil mileage, having reset it at the last oil and filter change (I've got one of those more often 998's). My Google maps and Spotwalla track my ride mileage just fine.
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
SpyderLovers Sponsor
We use A for tank of gas, B for this trip. Annual and oil are on a spreadsheet!
Joe Meyer
Ozzie Ozzie Ozzie
Same here for us.
Exactly! And since I don't have my laptop with me on every ride the maintenance information is on my Zumo 590 in the "Service History" app for redundancy.
I use then the same as Joe. Trip A is for currant tank, trip B is for currant trip GPS for low fuel warning and distance to nearest fuel.log book for oil change.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
My 2015 RTL trip meter will not reset if the parking brake is on. I use "trip A" for tracking fuel consumption. At the gas station, I have to reset it before I set the parking brake and stop the engine.
you must have one of the ODD BALL ones. I pump my gas, return nozzle to pump, turn on key, wait for receipt, by that time the "spyder wait" is over. reset trip meter, while still parking brake on
