Results 1 to 5 of 5
Hybrid View
    United States
    Default how to change spark plugs on 2014 rt 1330 engine
    does anyone know hoe to replace spark plugs on a 2014 rt 1330 engine. if so can you reply to my email.
    bardar226@gmail.com
    thank you,
    dave robinson
    203-565-1685
    May 2013
    Edmonton Alberta, Canada
    This is a good guide for replacing your plugs.
    The first time I did a plug change on a 1330 I was fortunate enough to have had this post to follow and it helped guide me through!
    2014 RT-Ltd , Cognac
    SoFlo
    Just did a spark plug replacement on our 2014 RTS. To make it a bit easier, I raised the main upper section slightly to facilitate removing the left side airbox.
    Overall, the worst part was dealing with the failing foam insulation. The foam was kind of a gooey mess, fell apart if your hand touched it. Time wise, removing the deteriorated foam took the most time, the spark plugs were easy and quick to change.
    Active Member deer30084's Avatar
    Tallahassee, FL
    Here's the easy way. Take your bike to your dealer. Write a check, use your credit or debit card. What could be easier?
    John F.
    Tallahassee, FL
    2015 Spyder F3 SE6, black
    BRP Driver/passenger Footboards
    BRP Adjustable Passenger Backrest
    Blue Ridge Windshield
    MRA X-Creen Tour, clear, clamp-on
    H4 LED Headlights
    F3 LED Fog Light Kit, LED Amber Halo Ring Kit, LED Tail Lights, F3 Rear run/brake/turn LEDs
    Easy Brackets
    Leatherworks, Inc. 120 Special Slight Angle Saddlebags
    Custom Dynamics Front Mud Flap LED lights, Street Magic Front Fender Tips, Double Feature Lens
    2-up rear shock
    Idler pulley kit
