Results 1 to 7 of 7
    May 2019
    Port Saint Lucie, Florida
    Default LAMonster Ultimate Floorboards
    May I ask, does anyone have these installed on their F3? I really like the looks of them, but I'm concerned about possible vibration, since there isn't the thick rubber buffer, between the frame and your feet, like stock pegs.
    Carsong
    Sep 2013
    Houston
    I have had them for over 25k miles. Lots of long days in the saddle. Vibration just is not a problem as long as you are wearing shoes. The side tube that the floorboards are bolted to is already fairly well insulated from the actual frame where the engine is mounted. And the Rotax is no Harley when it comes to vibration either.
    Blue Flame Spyder F3-S
    Active Member troop's Avatar
    Aug 2019
    Stoughton, WI
    I'm also considering floorboards, but .. just ... can't ... get .. past ... the cost. LaMonster and Slingmods (PB1) boards are $500+. I'll probably just try out the $160 hiway pegs from Slingmods. Good luck in your decision.
    2019 F3-S SE6
    Madstad 14" dark gray/20" light gray windshields
    TricLED aux lights/inner front fender aux lights
    Spyderlovers USB/12V powerport
    Baldwin cat delete pipe
    K&N air filter/Drilled airbox cover
    Big Bike Parts rider backrest
    Shad luggage/mounts
    Factory heated grips
    Two up shock
    H4 LED headlight bulbs
    Detachable passenger seat storage box
    ** Winter Upgrades Coming **
    1.) Upgraded swaybar/Q5 front tires
    2.) Dynojet PV3
    3.) Highway Pegs
    4.) Run/Brake/Turn rear tail light strip
    Very Active Member tofriendscreek's Avatar
    Mountain Home, Arkansas
    I’ve used Lamonsters floorboards on my F3 for 36K miles. I also use the associated foot pegs. They are solid, zero vibration and incredibly comfortable. I’ve logged up to 580 miles in a day with them. Pricey? Maybe. I look at it as an investment in my comfort and safety. On all counts, they were simply the best choice for me, a choice I’ve never regretted.
    2017 Intense Red, F3 Limited
    Jan 2019
    SW Georgia
    I bought CAN-AM Spyder accessories.com ultimate floorboards after installing Lamonster highway pegs on my F3 Limited. I would never have bought the highway pegs if I had purchased the floorboards first. The floorboards made the ride so comfortable for me.
    May 2013
    Apex, N.C.
    Look into making your own floor boards. I purchased some 1/4" aluminum and cut them to make a set for my spyder. I did a type of coating on them with bedliner, but then decided to mount rubber on them with some stainless steel bolts and washer style buttons. Cost me a total of about $40, and I am very happy with them.
    Member osj3's Avatar
    Aug 2018
    Greensboro NC
    I got the Slingmods (PB1) boards for my F3. I love them. really allows me to move my legs around while riding. No issue with vibrations. Love the LED light on back Floor bard that light up the front floor board. Very nice look too.
