Results 1 to 10 of 10
Thread: Won't start
    Active Member Spydermike's Avatar
    Mar 2018
    Maricopa, AZ
    Default Won't start
    Ok this never happened to me before. 2016 rtl. Just filled with gas tried starting, dash lights came on didn't turn over and just shut down. No lights no error code nothing. Ideas?
    2016 RTL "Boris"
    Foam Grips
    Utopia Backrest
    BRP Passenger armrests
    Bajaron sway bar
    LED Bumpskid w/remote
    Belt guard
    BRT rear lighting w/strobe
    High mount BRT w/strobe
    Dual a-arm LEDs w/turn signals
    Multicolor underground Halo lighting
    LED headlights and foglights
    FOBO TPMS
    Techgripper phone holder
    Lidlox
    Dual USB with voltmeter
    Dakota Digital Compass/Clock/Altimeter/Temperature Gauge
    Vredestein Quatrac 5 175/55R15 - Fronts
    General Altimax RT43 215/60R15 - Rear
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    Check the battery cable connections. Make sure clean and tight. If still a no go, may be the battery. Time to check voltage and load test. If you are able to jump start it -- odds are it's time for a new battery.
    Joe
    2023 F3
    Mar 2018
    Maricopa, AZ
    Got it hooked up to my buddy's pickup. Voltmeter reads over 13 when I try to start but doesn't turn over. Checked connections all good.
    2016 RTL "Boris"
    Foam Grips
    Utopia Backrest
    Bajaron sway bar
    Belt guard
    FOBO TPMS
    Lidlox
    Nov 2015
    Chardon, OH
    Not sure what "just shutdown" means, but did you remember the kill switch?
    Doug
    ”Freedom is not a loophole”
    INDIANA, USA
    Default No Start
    Do you mean 'Not Cranking' or something else?
    Check the Kill Switch first, check the battery and check if the cables are tight.
    Good Luck on your Mission.....
    ENJOY YOUR LIFE WITH A SPYDER
    Mar 2018
    Maricopa, AZ
    Thanks everyone.
    I had just filled with gas, and when I went to start the lights and everything just shut off and it wouldn't turn over. Pulled out my trusty Lamonster battery jump starter, hooked it up, but still didn't turn over. tried it again, nothing. 3rd time my battery pack didn't have enough juice left (I also didn't hit the brake when trying to start it, that could have been the problem too).
    Called my buddy who came and jumped me from his truck. checked the cables and after a little playing, finally got it going. Guess I'll be shopping for a new battery this weekend.
    Ryde on,
    Mike
    2016 RTL "Boris"
    Foam Grips
    Utopia Backrest
    Bajaron sway bar
    Belt guard
    FOBO TPMS
    Lidlox
    I knowingly lived dangerously battery-wise this week. On Monday it was quite chilly, around 40, when I headed out to the gym. Turned on the ignition and kill switch, all was normal but the Spyder cranked just a bit slowly as engine started and then the initial warning "Read the instructions" alert reappeared on the RECC screen. Noted the anomaly and rode off. Bike functioned perfectly riding Mon-Wed to gym but Wed on way home I stopped for an errand, came out of store, turned on ignition and all sorts of weird stuff flashed across RECC screen then went totally blank. On two successive retries, zero, zip, nada! I knew the battery was toast but after better than five years, why complain. Out came the Rugged Geek and after the routine battery door removal, an unsuccessful check that it wasn't loosened terminal bolts and a quick jump start I was on the way home again. Moral of story, if you don't travel with a Rugged Geek in your tool kit you may eventually wind up in a losing crap shoot with an aging battery. FWIW, the Geek was at 100% when I jump started the Spyder and was at 79% after the start assist.
    Get your Rugged Geek from Lamonster, http://www.lamonstergarage.com/batte...-motorcycle-4/.
    Jun 2010
    Las Vegas
    Jay, I hope you bought a new battery
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Mar 2015
    forrest above Reno, Nv
    I also have a 2014 RTS and replaced the battery last year. 5 years is plenty out of your battery that get so much heat and vibration (both battery killers) The battery in my 06 Dodge Magnum R/T lasted almost 14 years but it's in the rear of the vehicle with no heat and little vibration. Get a quality battery.
    Lew L
    2014 RTS , Circuit Yellow
    Sure did; went right out and bought a Yuasa YTX24HL factory filed and activated battery, expensive but I didn't want to mess with another brand.
