Results 1 to 9 of 9
    South Carolina
    Default Any suggestions on good A/mkt rear tire for 2017 RT? Size?
    what are some suggestions for a good rear tire for 2017 RT and best size to get proper diameter tire?
    Sep 2016
    Chillicothe, Oh.
    I'm on the second General Altimax. Worked well for me so I bought the second one. Go to the search box and type rear tire. Get ready to read until you starve
    2015 RT , Black
    I've been recommending the Vredestein Quatrac 5, ( available in 205/60 and 205/65 -15 )and lots of folks here have bought them …. A few years ago I really liked the Altimax ( and still do ) however, tires advance in technology all the time ….. now my first choice is the Q-5 … it is better than the Altimax ….. good luck … Mike
    Houston
    We have sold and installed quite a few of the Yokohama S-Drive tires for the rear. (Now the Yokohama Advan Fleva) Lots of very happy customers with this high quality tire.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    USA
    Quote Originally Posted by Lenk View Post
    Common diameters are OE 225/50R15, slightly larger diameter but narrower 205/60R15, recently mentioned 205/65R15, and the 215/60R15 which is larger and just very slightly narrower. I'm running the 205/60R15 and it does well. You will be very satisfied with any of the common tires mentioned in the threads. Depending on your choices you may run a different brand rear than on the fronts.
    h0gr1der
    Vermont
    I am also on my 2nd General Altimax RT 43 ( I have a 2014 RTS-SE6).
    It also has "replace Tire" in the tire, 3 different places in the tire, so it tells you when to replace the tire.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Nov 2012
    North Las Vegas, NV
    There are many choices in the 215/60R15 size. The General Altimax RT43 is a great choice.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    INDIANA, USA
    Default Rear Tire
    Yes, Three good choices for your Spyder rear tire.
    I would Not recommend getting a OEM (Kendra).
    Good Luck on your Mission.....
    ENJOY YOUR LIFE WITH A SPYDER
    Jul 2016
    Lake Frederick Va
    Dunlop Direzza DZ102 205/55/15 UTQG 460 AA Tire Rack $114.62. 18,500 on my 2016 RTL and still have perhaps 2K left. Diameter is 23.9” which makes it same diameter as OEM 225/50/15..
