Page 52 of 77 FirstFirst ... 24248495051525354555662 ... LastLast
Results 1,276 to 1,300 of 1903
  1. #1276
    Active Member Pooch's Avatar
    Feb 2018
    Texas Hill Country
    Rode to dealer for 9300 mile oil change and full service. 27* when I started out - thank GOODNESS for modular helmet, heated gear, seats, and grips.
    All systems GO... no problems found.
    Did advise the rear original Kenda tire had about 2000 more miles left on it.
    Had the top box shock replaced under warranty - works much better than the original. But I'm keeping my notched tree twig I used to prop it open - just in case.
    2021 RT Ltd, Marsala Red/Black, Dark
    New course heading Mr Sulu: 2nd star to the right and straight on til morning...
  2. #1277
    Dec 2020
    Hartwell, Ga
    Ordered two of the Vredestein Quatrac's for the front of my Spyder.
  3. #1278
    Sep 2017
    INDIANA, USA
    Default Installed LED Headlights
    I installed my Christmas present, LED Headlights.
    Yesterday was a beautiful day for working on the Spyder.
    Just took a hour from start to finish.
    I had watched the U-Tube video.
    Stay Healthy. ....
    ENJOY YOUR LIFE WITH A SPYDER
  4. #1279
    Oct 2016
    Sebring, FL
    Where did your order your VQ's, and were they the same size as OEM's?
  5. #1280
    Dec 2020
    Hartwell, Ga
    They are not the OEM size. They are 165/60R15 and I got them at Tire Rack.
    There are only a very few options for the OEM size outside of the Kenda's.
  6. #1281
    Oct 2016
    Hamburg pa
    I installed a set of fold down flags on my 21 STS
  7. #1282
    Active Member slhanks004's Avatar
    Nov 2022
    Gilbert, AZ
    Not today - but this past weekend I installed a set of Tricled Afterburnerz taillights from SlingMods and replaced the BRP medallion on the frunk with a custom design I bought from a guy in Canada.
    Left side stock/right side with Afterburnerz
    Afterburnerz also have sequential turn signal LEDs, which is really nice.
    New custom Spyder badge on frunk
    Scott (slhanks004)
    Gilbert, AZ USA
    2022 Spyder RT Limited - Carbon Black
    • Pedal commander
    • Baja Ron sway bar
    • TricLED tail lights
    • TricLED driving lights
    • Corbin seat
    • BRP rider backrest
    • Lamonster topcuff (2) w/ RAM mounts
    • 12v/USB docking station
    • Garmin Zumo XT
    • RLS cat delete pipe
    • IPS highway pegs
    • IPS belt tensioner
    2022 RT-L , Carbon black
  8. #1283
    Jan 2023
    Michigan, USA
    Did the first, and a most important, mod to my 1-week old F3S... added a battery tender connector to the battery. I left the connector up by the coolant tank, under the service cover.
    Then promptly came back inside the house, as my hands were almost numb from the cold.
    Chuck
    2022 F3-S Special , Manta Green
  9. #1284
    Member vulkus's Avatar
    Dec 2022
    QLD, Australia
    Changed the height setting for the rear foot boards.
    2015 Spyder RT Special series Se6
    Really a mutant cross between a special series and a Limited.
  10. #1285
    Feb 2020
    Minnesota,USA
    Changing out OEM to BaJa Ron's "ULTRA 3 Pcs Sway Bar"
    Finally got around to changing my OEM sway bar to BaJa Ron's Ultra 3 piece. Got my RTL lifted about 20 inches placed solid on my jack stands. Knowing this wasn't high enough to get the OEM bar out, but was fine for getting it disassembled and dropped down on 1 side. Looked over the situation and said to myself, "Self, Are you ever going to put this Old OEM bar back on?" The answer was , "Hell NO!" So, a 3 second go at it with the "gas wrench" and it fell out of there in 2 pieces. Everything went back together as fast as my 72 year old "bag of bones" would allow. Job well done and can't wait till our weather straightens out so I can try it out. "Come-on Spring" Bill
    2020 RTL Chrome, Marsala Red "Non-Directional Tires, Centramatic Balancers"
    Front- Kumho KH-16 175/55r15 @17psi, Rear-General Altimax RT-45 215/60r15 @20psi
    BaJa Ron Ultra 3 pcs sway bar kit
    7jurock 25" tinted windscreen w/flip
    Frogman Dave's "Signal Button"
    If in Doubt, Don't Do It!
    " Pros: Excellent Bug Killer, Cons: Pizz Poor Pothole Dodger"
  11. #1286
    Dec 2020
    North Germany
    Finally cleaned the Spyder after I'd hit the dirt which was left on the road by a farmer. It already smells a little bit in my garage
    It's always a challenge cleaning the bike with high-pressure out of the wheelchair
    Last edited by Peter Aawen; 02-22-2023 at 03:02 AM. Reason: Fixed attach display & Caps + 's... ;-)
    modified 2020 F3-S for paraplegics including handbrake, wheelchairmount etc.
    2020 F3-S , pedalbox black
  12. #1287
    Active Member Latrappe's Avatar
    Nov 2022
    Flaxton Queensland Australia
    Quote Originally Posted by askitee View Post
    Not specifically today but over the weekend removed the BRP shocks front and rear and fitted Wilbers shocks. Not a fun activity but done. Test ride Sunday on my 250k m test track of highways and country back roads found a few problems
    1. Cant stop grinning at how much better the 17 RTL is to ride, this isn't an incremental improvement but a huge one. As soon as I reversed out of the garage over a small ledge in the concrete, I could feel the difference in the way the shocks behaved.
    2. Because the new shocks are finally doing what suspension is supposed to, I cant stop looking down at the front wheels hugging the road.
    3. To finally have the ability to adjust compression and rebound settings is right up there with holding an overly full bladder for 10 hrs and finally getting to wee
    4. I have not played with any settings (seems a contradiction I know from the above comment) because the calibration by Wilbers based on my weight and riding prefs is spot on. This will change when my copilot comes for a ride who's weight has been factored in too
    They are pronounced as Wilbers - but you should pronounce the same way Homer Simpson pronounces Doughnuts - that mesmerized tone he uses.
    You make me jealous one if the things I truly want get , I just fitted a new Led H7 low beam to replace the Halogen lights which my left one kept blowing which is the same as Europe here which is your fog lights over there.
    2019 Can Am Spyder F3S
    ICSI Ride Hand Brake Kit as my right leg and foot does not work that well due to MS
    The Ultimate F3 Floorboard
    Baja Ron Sway Bar
    Shad Saddle Bags
    Lamonster F3 PACKRACK
    SHAD 58X in Carbon finish - Expandable TOP Case
    Pedal Box
    IPS Belt Tensioner and Handlebar Riser from Lamonster
    K&N air filter
    INNOVV K5
    Wilbers Nite Line Shocks
    RLS Cat Delete
    Floating Rotors with EBC Brakes for the front
    I am now broke
    I Should mention the Boss has a 900 Ryker Ralli next to my bike
    2018 F3S , Monolith Black
  13. #1288
    Very Active Member SLICE's Avatar
    Aug 2022
    manatee county Florida
    strapped a butt buffer on the 22-rtl hopefully that will help with the brick of a seat can am gave me.
  14. #1289
    Very Active Member al0vely's Avatar
    Apr 2016
    Indiana
    Over the last few days installed accessories on new to me 2020 RTL:
    - Hitch from my F3L
    - Short reach bars from my F3L w.X grip and Garmin mount
    - Isolated fuse block and wiring harness Show Chrome 41-201 (Value Accessories)
    - Front fender amber and red LED's - Show Chrome 41-187 and 41-202 (Lamonster)
    - Wesbar 5 wire to 4 wire converter trailer connector (Ebay)
    - Kenway 4 flat connector extension (Harbor Freight)
    - RT 9 way brake flasher module - TRIC-F3TFLASH (Value Accessories)
    - Rear lights LED run, brake, turn - TRIC-RT-RBT20 (Value Accessories)
    - Motohorn dual horn (Lamonster)
    - Floorboard risers from (Lamonster)
    Yet to install - USB charging port w.voltmeter, power cable for Garmin, spring and strut for drivers seat and
    rear trunk, key cover
    Yet to purchase - UltraGard cover, Ciro drink holder, Backrest (Utopia or BRP), foam grips
    I would like more stuff but my installer is losing patience with me *lol* - he says I micromanage .
    Love my Spyders
    2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
    2014 RTS Circuit Yellow purchased 3/2/2018
    2020 RTL Petrol Blue purchased 1/27/2023
    Girls on Spyders #3195
    No more 2 wheels
    2020 RTL , Lamonster floor board riser Petrol Blue
  15. #1290
    Danbury Connecticut
    Here's what I did today.
    A) I got cold in my garage. It's 35 °F outside and raining.
    B) Worked on my Spyder.
    I've been having problems with the GPS. One of the spring loaded electrical connectors has been dodgy since last summer. On a ride a week ago, the thing finally gave out, so I replaced it. I had to replace the entire cable.
    I installed the SpyderPops vision kit on my RT as soon as it was available in 2020, One of the connectors was intermittently disconnecting. I removed it and hard wired the connection.
    I had added a garage door opener in 2020 using a windshield switch to operate the opener. I used the OEM blank position for this switch.
    This really upset my CDO. (That's OCD with the letters in the correct order). So I took the opportunity to relocate the switches in a more logical position with the two heat controllers next to each other in the center.
    Just for completeness, I've shown a photo of the wiring to the new(er) switch.
    Damaged GPS Mount
    Repaired GPS Mount
    Vision Kit connector that was failing intermittently:
    Connector removed and hard wired:
    Installed Garage Door Switch prior to my CDO:
    Control Panel AFTER CDO has been satisfied:
    Just for completeness, this is how I wired the garage door switch:
    So that's what I did today.
    IBA #47122
    2020 RT Limited Asphalt Grey
  16. #1291
    Aug 2018
    Piperton, TN
    where did you get that garage door button?
  17. #1292
    Aug 2022
    wired my new GPS into SLEDGE electrical system.
    works with key on only.
    no fires
    no explosions
    NO BEER.................D'OH
  18. #1293
    Jan 2021
    Colorado
    3 New tires,oil changed,checked brake lines gonna take a spin soon.
    2012 RSS , Black&Green
  19. #1294
    Oct 2021
    TX
    I put on a Lamonster Spyder Cuff and Phone Phang. I think Im going to like it.
    2019 RTL
    2019 RTL , Blue
  20. #1295
    Oct 2021
    Wichita, KS
    Quote Originally Posted by jchadwi View Post
    I love mine!
    Peter Pan has struck again!
  21. #1296
    Vermont
    Nothing.
    Still on a battery maintainer.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  22. #1297
    Jan 2023
    Michigan, USA
    Moved the pegs to position #4, installed the SE Performance Adjustable Brake Rod Kit, and adjusted the brake pedal to work with my wonky ankle.
    Sooo much more comfortable!
    Then I didn't ride it because... Winter.
    Chuck
  23. #1298
    Aug 2022
    Quote Originally Posted by Impster View Post
    Chuck
    SE Performance Adjustable Brake Rod Kit was a life saver, i came very close to selling the trike because of my bad knee/hip
  24. #1299
    Active Member hut1's Avatar
    Sep 2009
    Greenwood, DE
    Installed a cat delete pipe and Akrapovic muffler on my F3S (thanks MotorcycleDave). Have not had a chance to test it out yet; only idle and revs in the garage and driveway. I'll reserve judgement until after I've had a chance to take a decent ride.
    Skip H.
    '21 Can Am Spyder F3 S
    '97 Honda Goldwing w/Hannigan Astro 2+2 sidecar
    [img]
  25. #1300
    Sep 2015
    Chilliwack, BC. Canada
    Quote Originally Posted by hut1 View Post
    That’s the setup I have on my ‘14 RTS, and I love it. Hope that it “works” for you!
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
