Page 46 of 77 FirstFirst ... 3642434445464748495056 ... LastLast
Results 1,126 to 1,150 of 1901
  1. #1126
    Oct 2016
    Sebring, FL
    Very nice!
  2. #1127
    Vermont
    Nothing
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  3. #1128
    Very Active Member rjinaz86323's Avatar
    Mar 2021
    Arizona high country
    I finished putting on the Ultimate seat. If it will quit raining (more like sprinkling) I would like to do a day trip to get it broke in a little before our trip.
    . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2018 F3 Limited - Intense Red Pearl . . . . . . . . . . . . . . . . . . . . . . . . . . .
  4. #1129
    Active Member RangerRick's Avatar
    Jul 2022
    Coos Bay, Oregon
    Just did the “canisterectomy” Routed the hose clear back behind the Brake reservoirs, To tired to ride it today, will check it out tomorrow.
  5. #1130
    Sep 2018
    Maryland
    Put on the BAJA Ron Sway Bar!
    2021 RT Limited , Fast Red
  6. #1131
    Mar 2015
    forrest above Reno, Nv
    Yesterday I finished up an oil change after our 3 week trip to the 3 wheel rally in South Dakota. Used Amsoil even though the Rotella 15w40 T6 had miles left on it. The spyder seemed a bit noisy on hot start up. Something I never noticed with the Amsoil.
    Lew L
    2014 RTS , Circuit Yellow
  7. #1132
    Oct 2016
    Sebring, FL
    Are you saying your RT sounds a bit more noisy with the Amsoil on startup? Maybe I misread?
  8. #1133
    May 2019
    Michigan
    Brought it home from the dealer, coated it thoroughly with Lemon Pledge and read the owners manual cover to cover.
    2022 RT Ltd, Deep & Dark Marsala
  9. #1134
    Oct 2015
    Lynden, WA
    Installed my F3 SpyderPops bump skid.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
  10. #1135
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    Installed my new Helibars, short antenna and adjustable wind deflectors.
    2021 RT Base - Petrol Blue
  11. #1136
    Feb 2022
    very southern tip of Texas
    Per advice from many here on this forum, started the process of changing out the factory Kenda tires on my F3-S Daytona. Only has 1,226 total miles on it. Installed a Riken Raptor HR, size 215/60R15, pressure set at 18psi. Date code 3921 replacing a 1316. Adjusted belt tension down to +/- 165 lbs, trying to eliminate some vibration at the 65-69mph and 74-77mph marks. Also sucked out all the fluid in the clutch reservoir and replaced with fresh Dot4 fluid. Will do a complete clutch and brake flush and bleed in the near future. And installed a generic ~$15 BeadRider on the seat. A test-ride is in order tomorrow to check my handiwork.
    Have a pair of Continental ContiProContact tires, size 165/60R15, on the way for the front. Should be here mid-week.
    White 2015 F3-S SE6 - “Gypsy” (hers)
    Yellow 2017 F3-S Daytona 500 SM6 (his)
  12. #1137
    May 2021
    Upstate NY State
    As promised, here are some pics of my Spyder.
  13. #1138
    Jun 2022
    Maryland
    I attempted to figure out how to reverse the wiring on the Shift Paddle so my thumb down-shifts and my Index finger up-shifts. Seems to be a little more complicated than I was bargaining for. will head back into the shop manual to revisit my plan. Oh Joy!
  14. #1139
    Oct 2016
    Faribault, MN
    Just a little stealth upgrade, Thanks Lamonster for the PB, St2 purchased direct
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
  15. #1140
    Jan 2021
    New Kent, Virginia
    Spark plugs already???
  16. #1141
    Jul 2022
    Coos Bay, Oregon
    Installed Lamonster Leather-Like Grips
  17. #1142
    Mar 2021
    Got back from Sturgis last week, but had a full week of yard work, due to the fact that it rained everyday we were gone. So today I finally got around to washing and waxing the Spyder today. Looks much better.
  18. #1143
    Active Member Partzman23's Avatar
    Jul 2020
    Sikeston ,Missouri
    Default Added pinstriping to my Spyder
    Hi guys, I added some pinstriping to my 17 RTL Asphalt Grey Metallic Spyder. I used silver Metallic double pinstriping. Take a look -
    I added pictures to my album under my profile. Go there to see the pictures then come back and tell me what you think.
    You can see some in the picture below.
    Last edited by Peter Aawen; 08-23-2022 at 11:01 PM. Reason: Mettalic - Metallic %-)
    2017 RTL Asphalt Grey Metallic Chrome
    2017 RTL , Asphalt Grey Mettalic
  19. #1144
    Oct 2015
    Lynden, WA
    Tried to adjust the preload on the F3 front shocks while still mounted on the bike.
    Couldn't get the locking rings loose. Looks like I'll have to pull the shocks and adjust off the bike.
    Removed the old gas cap. Ground wire was a challenge to remove but ultimately got it out.
    Waiting for the new gas cap to arrive.
    David C
    2016 F3T
    Rear IPS Pack Rack
  20. #1145
    Jul 2022
    Coos Bay, Oregon
    Installed the Safety LED Bullet-Brake & Strobe Light. Talk about Bright, this should get drivers attention. Put it in the flash mode. The only Issue I had was , the pigtail that I was to put in the line to one of the tail lights was not correct, the instructions showed 3 different types according to your model, mine is the ST. But the one they sent which shows it's for the ST, well mine was not like that, The one that showed for the RT model is what mine needed. Thankfully I had a a Posi-tab connector, so installation was a breeze.
    https://tricledusa.com/collections/s...33943001235501
  21. #1146
    Feb 2022
    Finally got a set of Continental ContiProContact fronts (165/60R15) delivered. Got them swapped on and balanced, and I installed them back this evening. So, finally, 3 new, good tires. Test ride will have to be another day.
  22. #1147
    Oct 2015
    Lynden, WA
    Replaced the fog light switch.
    The original unit failed while I was replacing the gas cap. Go figure...
    David C
    2016 F3T
    Rear IPS Pack Rack
  23. #1148
    Very Active Member SLICE's Avatar
    Aug 2022
    manatee county Florida
    detailed and ceramic coated, finished just in time for the T-storms
    Last edited by Peter Aawen; 08-30-2022 at 09:07 AM. Reason: Removed ' ' before punctuation...
  24. #1149
    Member KSCRZR's Avatar
    Aug 2020
    Kansas
    Took off the muffler so its ready for Wednesday when I get a delivery. I had finally ordered my Crusher exhaust from RLS, shortly after some guy in Canada ordered 25 of them though, so it was a little longer then I hoped to get it. Unfortunate thing is I leave Thursday for Rocklahoma so I won't have much of a chance to enjoy it till after Labor Day.
    2012 Spyder RT Limited in Lava Bronze Metallic
    2012 RT Limited , Lava Bronze
  25. #1150
    Oct 2015
    Lynden, WA
    Installed and road tested a CalSci Windshield.
    The jury is still out on keep or return.
    David C
    2016 F3T
    Rear IPS Pack Rack
