Page 26 of 76 FirstFirst ... 1622232425262728293036 ... LastLast
Results 626 to 650 of 1882
  1. #626
    Active Member Partzman23's Avatar
    Jul 2020
    Sikeston ,Missouri
    Yesterday I installed new tires on the front of my Spyder. Federal Format AZ01 today I got the new rear tire installed and remounted. General Altimax Rt43
    Also put on the missing belt guard while I had it apart. Makes it easier to get the nuts off the bolts holding on the belt guards on the Spyder while the rear tire is off .You get new clamp nuts to replace the original when you get the belt guard so you don't have to get in behind the guard to hold the nuts when putting it back together.
    These new tires are awesome.
    2017 RTL Asphalt Grey Metallic Chrome
    2017 RTL , Asphalt Grey Mettalic
  2. #627
    Apr 2019
    PA
    Installed second strut in trunk. It now holds my rack up fine with the bag on. Removed and installed new seat strut Sachs SG359011-30 lbs which pops up on its own with helmet and gel seat inserts on both drivers and passenger.
  3. #628
    Had both Spyders annual service. Mine also got a new rear tire (K9). She also bought $1,100 worth of lights and a chrome trunk rack.
    Lamonster garage did it for us. It was a cold ride going (41), but 61 coming back.
    Sep 2017
    Durham,Maine
    Put a new set of Elka stage 2 shocks on the front end of the 2012 RTL!! What a different ride, very nice, corners a lot flatter!! Love it!!
    2012 RTL , Pearl
  5. #630
    Oct 2015
    Lynden, WA
    Bought a few parts to build a Third Peg for my F3T.
    Assembly takes place this weekend after HoneyDo.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
  6. #631
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by Haze View Post
    Both the wife and I use that middle per to get on and off. The best addition I did to the bike.
  7. #632
    Oct 2020
    Arizona
    I have been thinking about Baja Ron's shock adjusters, and I found this video. https://www.youtube.com/watch?v=CKanoQgyDPU
  8. #633
    Oct 2020
    Arizona
    Quote Originally Posted by Snoking1127 View Post
    Well I installed the adjusters today. I did without removing the frunk, crazy me! We should have been born with four fingers on each hand with two opposing thumbs on each, one long and one short like we have now. Put one full turn on each as a starting point, will have to go back and see what Ron was recommending. I recall 1.5 to 2 turns.
  9. #634
    Oct 2020
    Arizona
    So to get the top bolt back in which goes for front to back through the mount/shock end, I got it in place and pushed the lower bolt in from the rear until it was just coming out of the front mount hole. Then said many nasty words sliding that top bolt in from the front while pushing out the guide bolt. Put weight back on the shock an was able to tighten the nut without a wrench on the bolt head. I was able to loosen the top nuts the same way, trikes weight on the shock, and just a ratchet on the nuts.
  10. #635
    Oct 2015
    Lynden, WA
    Built a 12V harness to power my GPS and USB devices and Camera (Friday). Installation is on Saturday.
    David C
    2016 F3T
    Rear IPS Pack Rack
  11. #636
    Jan 2015
    southern WI
    New battery and brake pads. We're getting some needed rain to wash all the crud off the roads, now, if the sun would just shine and warm up a bit...It is still March, and it ALWAYS snows at least once in April in southern WI. Patience.....
    2021 RT Limited
    2016 RTS , Pearl White
  12. #637
    Oct 2015
    Lynden, WA
    Installed my Third Pegs, wired the GPS and USB.
    David C
    2016 F3T
    Rear IPS Pack Rack
  13. #638
    Sep 2017
    Wa.
    Used a wet rag wiped down wife F3L an then dried it. Then put 2 coats of wax on it. Took my RTL on a drive with wife on the back seat an got a burger for lunch. Put some things in it might need when I drive it to Vancover to have it serviced Friday.
  14. #639
    Oct 2020
    Arizona
    So I have done my handling upgrades one at a time:
    1. Federal Formoza Az01
    2. Bajaron sway bar, a few weeks later.
    3. This week the Bajaron shock adjusters.
    I just went for a test spin to the overlook at Canyon Lake. Set at 1.5 turns on the way out and 2 turns on the way back. The 2018 RTL is handling the best it has. Loving it!
    I have to say those springs are pretty strong when trying to compress them.
  15. #640
    Active Member redrazor's Avatar
    Mar 2020
    Martinez, CA
    Replaced brake pads on our 2014 RTL last weekend. 4 hours from start thru test ride. Use parts I got from BajaRon. Old pads not too worn out; but noisy on stops. Nice and smooth and quiet now. Gave me a chance to really give the front wheels a good cleaning/shining.
    Also: finally bought a nice 6' by 12' utility trailer and spent all day learning the best way to load and strap down the RTL. It's a Big Tex 35SA single axel with nice loading ramp. Easy to load and useful for other hauling jobs. Spent a few hours installing front wheel chocks; but overall a pretty easy job. Looking for our first trailer trip coming up at end of April.
  16. #641
    Active Member Pooch's Avatar
    Feb 2018
    Texas Hill Country
    Today was 2nd day of adjust/test the Heli-Bars on my new 2021 RTL. So far, so good.
    Am greatly pleased with myself that I actually went ahead and spent the bucks at the beginning to have the many adjustability options.. I am picky about my riding comfort...like the Princess and the Pea. Knowing me I usually would have tried several less expensive purchases, gotten frustrated, then finally purchased the Heli-Bars as a last resort, thus having sunk a lot of frustrating time and money.
    Its like heated gear which I would not buy for years until this past December...always layered up...was never as warm as I wanted to be. So as a personal Christmas present to me I bought a heated jacket liner that direct wires to the battery. OMG..that thing is awesome! SO many fewer clothes to smother through, so warm! Love it! Also bought heated gloves. YES!!! Should have done this years ago.
    2021 RT Ltd, Marsala Red/Black, Dark
    New course heading Mr Sulu: 2nd star to the right and straight on til morning...
  17. #642
    Nov 2018
    Waynesboro, PA
    Pulled the Spyder in for some maintenance and upgrades. Front Spyder.jpg Right Side Spyder.jpg left Side Spyder.jpg So I have some work to keep me busy.
    1. Change Oil, Oil Filter & seal, Transmission & seal, 2 new hex oil Plugs & seal.
    2. Change headlights to Led lights and replace bad Auxiliary Lights.
    3. Add Lamonster Long Horn Led lights to mirrors
    4. Add Lamonster Magic Mirror Magnets.
    5. Add Bajaron Swaybar kit.
    6. Replace rear tire with Kendra Kanine K20 with new o rings and seals.
    7. Replace 14 inch front wheels with 15 inch wheels and tires.
    8. Change all 3 Brake calibers bleeders to speed bleeders.
    9. Change all Brake pads with ECB pads.
    10. Change Brake fluid.
    11. Find and fix leak in air bag system.
    12. Change GPS system from Garmin 660 to 595.
    13. Add Centramatic Wheel Balancers.
    14. Change Air Filter.
    15. Add cargo nets to rear bag areas.
    16. Replace rear Trunk shock.
    My Spyder
    2012 RTL , Brown
  18. #643
    Oct 2016
    Sebring, FL
    Holy Smokes, you do it all.
  19. #644
    Mar 2015
    forrest above Reno, Nv
    Say Copper, Some real good farkles.
    I reformed the mounting brackets on the led driving lights I purchased from Larry D a month ago. Before they touched the frunk sides at full lock---- now the don't. BTW, they are hooked up the fhe fog lights so now I'm all LED up front and can night into day with the touch of a button.
    Lew L
    2014 RTS , Circuit Yellow
  20. #645
    Nov 2018
    Waynesboro, PA
    Quote Originally Posted by Lew L View Post
    Lew L
    The Led Head lights I got have no fan and fit in side the head light housing good and you can put the cover back on with out a problem. the LEDs are 12000 LM so they should light up a lot better than the old halogen bulbs.
    My Spyder
    2012 RTL , Brown
  21. #646
    Nov 2017
    San Francisco Bay area
    Had my 28 k service. Ouch
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    Mirror Mount Turn Signal Indicator
    2015 RTL , Yes Pearl White
  22. #647
    Very Active Member rjinaz86323's Avatar
    Mar 2021
    Arizona high country
    Managed to get my first ride in today since I brought it home. Little over 100 miles. Stopped for gas and had a hell of time getting the gas cap close, it fits so tight. Got to test the ABS brakes. Had a javelina run across the road right in front of me.
    . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2018 F3 Limited - Intense Red Pearl . . . . . . . . . . . . . . . . . . . . . . . . . . .
  23. #648
    Feb 2018
    Texas Hill Country
    I've had a hard time getting the gas cap OPEN on my 2021 RTL.
    In fact I had to ask for assistance from a nice muscular gentleman - he opened it ok with one hand but did say it was "firm".
    Takes me two hands at that odd angle. Don't know - maybe I was just out of spinach on that day...
  24. #649
    Feb 2019
    Portland, Oregon
    Re those hard to open/close gas caps....Smear some lubricant on the mating surfaces, preferably a silicone base lube. Many say that did the trick.
    My route was to dismantle the locking mechanism in the cap and file the latch down until it closed easily.
  25. #650
    Dec 2020
    North Germany
    mounted the real-carbon-wrapped-parts
    2020 F3-S , pedalbox black
