Page 24 of 76 FirstFirst ... 142021222324252627283474 ... LastLast
Results 576 to 600 of 1879
  1. #576
    Oct 2020
    Arizona
    Quote Originally Posted by Snoking1127 View Post
    What are the little flags in the bottom left of my 2018 display? One is larger than the other with a dotted line between them. Did not see anything in the manual, but they show in one of the pictures.
    I figured it out. That area tells you if you have Trip A or B selected. If you select total the flags go away and you display odometer on the dash.
  2. #577
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by K80Shooter View Post
    I then installed a Tackform phone holder from Motorcycle Dave
    May I ask how many bananas you paid for it?
  3. #578
    Dec 2020
    Hartwell, Ga
    Replied via PM
  4. #579
    Member Enygma6's Avatar
    Feb 2021
    San Diego
    2021 RT Sea-to-Sky , Highland Green
  5. #580
    Dec 2020
    Hartwell, Ga
    Nice!! Enjoy.
  6. #581
    Aug 2018
    Piperton, TN
    Quote Originally Posted by Enygma6 View Post
    You got a S2S!!! How do you like it? I am curious if the belt noise has been reduced as they say a new pully wheel was utilized and more sound deadening. Also, how is the mirror wobble. I am so excited for you!
  7. #582
    Feb 2021
    San Diego
    It's fun so far, but I haven't ridden enough to get a good intuitive feel for it yet. Just the (slightly) scenic ride home from the dealership last night.
    I did notice a bit of wobble on the left mirror, I'm going to have to pay a bit more attention to that, and it seemed there were a few odd noises that I need to track down still. This is my first spyder, so I'm not particularly familiar with the pully sound. I did see another thread that mentioned it on here earlier this evening so now I'm curious.
    Still trying to get used to fining the turn signal switch (so many buttons on the handlebars!)
  8. #583
    Dec 2020
    Hartwell, Ga
    Today I added the Lamonster mirror locks on my 2020 RT Ltd. There's no way the mirror will vibrate now. It was a very easy upgrade and only took about a half hour.
    IMHO they are worth every penny that they cost and should have come from the factory with something like this.
  9. #584
    Oct 2020
    Arizona
    I installed some tie down rings on the front lower shock bolts today after turning them around.
    Got these on Amazon.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
  10. #585
    Dec 2020
    Hartwell, Ga
    Thanks, that a lot better price than some others I've saw. Mine are on the way.
  11. #586
    Dec 2020
    Hartwell, Ga
    I installed the TricLED Sequential Fender LED's which I got from Value Accessories,
    I had thought about just getting the plain turn signals for the fenders but I really hated the red sticker/reflectors and wanted to replace them also. The only option I found for those were 149.95 a set and thought that was to much(for the red lights alone) then the amber ones added ran the price up more than the sequential's.
  12. #587
    Oct 2020
    Arizona
    And you will have a set for a friend also. Or you could put them on a trailer for the other end of a ratchet strap.
    They are 304 SS and I put a SS washer, SS lock washer and blue loc-tight on threads. I had brought a cheap same trolley jack at WM the other day, so I jacked up each side and put my blocks under the tires to make room for the trolley jack to go under the belly placing a little off to one side in the area near the sway bar recess and lifted that side until the bolt came out and I was able to slide it back in from the rear. Then repeated it on the other side.
  13. #588
    Aug 2019
    Stoughton, WI
    Added some spot lights to my Spyder Extras grill guard..
    2022 RT Sea To Sky
  14. #589
    Vermont
    I didn't add anything to my spyder today.
    It is in hibernation until April.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
  15. #590
    Oct 2015
    Lynden, WA
    Waiting patiently for delivery of the beast.
    Constructing a set of fog/driving lights.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
  16. #591
    Mar 2015
    forrest above Reno, Nv
    Quote Originally Posted by Haze View Post
    Hi Dave,
    I'll be adding driving lights as soon as they arrive from the other side of the country------- think the weather is slowing them down a bit.
    Lew L
    2014 RTS , Circuit Yellow
  17. #592
    Feb 2019
    Portland, Oregon
    I just had to come up with a winter doldrum Spyder project and I never liked that small, dismal badge in the grille. First, I made a mounting piece out of 3/4" X 1/4" aluminum bar stock. Then I worked with a vinyl sign maker for the lettering and applied it to the polished aluminum. I also took advantage of the grille being out of the bike and put window screen on the backside.
    The drab original...
    The badge....
    In the grille....
  18. #593
    Active Member mehcoib's Avatar
    Apr 2019
    Montreal, QC
    Today, I... did something REALLY stupid!!
    On another thread I was asking whether or not I should buy the service manual before I replace the spark plugs on my ST. Well, while waiting for the spark plugs I ordered, I decided to take care of the brakes (cleaning, and doing whatever I can to lower the squealing noise).
    Everything was going nice until I put the calipers back... I didn't know the torque so I tightened the screws too much and one of the srews broke inside
    I managed to drill the screw (with cobalt bits) and remove it
    Then I bought 4 new screws, the service manual, and I put everything back (tightened to correct torque!).
    (why am I not able to insert pictures into the text? Only attachements. When I click insert picture then I select the pic I want but there's no "OK" button at the bottom)
    2015 ST-S SE5 , Blue & orange
  19. #594
    Mar 2013
    I installed a set of Baja Ron's front shock adjusters to my 2020 RT. Did two turns and it really tightened up the handling.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
  20. #595
    Feb 2019
    Portland, Oregon
    For the first time in many months, we have our 11 year old great-grandson with us. Yesterday, he and I installed new brake pads in the Spyder's front calipers - no, the originals were hardly worn, but I wanted to upgrade to EBC HH pads. On the first wheel, I would start an operation to show him what to do, then he'd take over. There was the sanding of the pads and the cleaning and dressing of the rotor and much more. When that wheel was done, we moved to the other one and I had him do it all, which he did with no input from me. High fives!!
  21. #596
    Jan 2021
    Colorado
    Fitted an F4 23in windshield, larger brake pedal, 2 acc sockets near the front speakers, & a driver's backrest
    Last edited by Peter Aawen; 02-15-2023 at 08:54 PM. Reason: ' 's so it can be read! :-/
    2012 RSS , Black&Green
  22. #597
    Dec 2020
    Hartwell, Ga
    Installed the Lamonster belt tensioner on my 2020 RT-L.
  23. #598
    Oct 2020
    Arizona
    Set the clock back to AM/PM again, why does it keep switching on it's own to military 24hr mode???? I was discharged after 4 years in the USCG on January 3rd 1969. Stand down Spyder clock!
  24. #599
    Active Member Partzman23's Avatar
    Jul 2020
    Sikeston ,Missouri
    Smile What I did to my Spyder today
    I installed the following items on my Spyder today.
    LG tie down rings on front shock bolts
    LG magic mirrors
    CASA flowing pegs
    Butt Buffer seat pad
    2017 RTL Asphalt Grey Metallic Chrome
    2017 RTL , Asphalt Grey Mettalic
  25. #600
    Oct 2015
    Lynden, WA
    Still working on a set of mounts for my fog/riding lights.
    Lots of cardboard templates.
    Waiting for the "Beast" to be delivered.
    David C
    2016 F3T
    Rear IPS Pack Rack
