Results 1 to 14 of 14
Thread: UFIT system
    Oct 2013
    rome new york
    Default UFIT system
    Buying a new F3L from different state and had to the Can Am site for the UFIT system. Which is the 5 position at 6'2"
    How accurate is there Chart??
    TIA
    Sep 2009
    La Valle, WI
    5 is farthest away.
    2018 F3 Limited , Oxford Blue
    Active Member Smokes's Avatar
    Jan 2017
    Melbourne, Australia
    I'm just under 6' and number 5 fits just right.
    Andrew
    Melbourne Australia
    2016 F3L Spyder
    Now, wash your hands
    Aug 2019
    Stoughton, WI
    I'm 6'3"/36" inseam and use P5 for trips. For everyday riding, I prefer P4 as I feel it gives me a more aggressive foot position.
    2022 RT Sea To Sky
    Oct 2013
    rome new york
    Is it easy to switch from 5 to 4 position??
    Mar 2013
    Quote Originally Posted by bmccaffrey View Post
    Yes. the only thing that takes more time is switching the brake rod. What I did was try the different positions while setting on the Spyder to determine which position I liked the best (4 for me) and then purchased Lamonts #4 brake rod as that lowers the peddle.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Sep 2019
    ON - Ontario
    I'm 5'8 and I have a very short torso and long legs, I went to #5 and it works perfect for me. #4 might have worked also but didn't want to chance it. My forward controls on my motorcycle are 4 inches forward and my buddy is 6'4 and fits him perfect, so you get an idea how #5 fits.
    Aug 2019
    Northern Virginia
    Agree with all the other comments. I'm 6'3" and position 5 is perfect. Doesn't feel like a feet forward position. My legs are pretty close to 90 degrees. Only issue is that the Lamonster frame mount drink holder won't work because the bottle hits my leg but that would be the same problem in any of the positions. Go with #5. Very comfortable
    Oct 2013
    rome new york
    Also says long reach handlebars. Any comments on them?
    TIA
    Mar 2017
    To lower your pedal, you can drill a hole as illustrated . Finer adjustments can be had by adding washers under the rubber.
    Mar 2017
    board software sux for putting pics and updating after a post.
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by Rattlebars View Post
    Nice tip.. Thx !
    2022 RT Sea To Sky
    Mar 2013
    TIA
    The best way to determine what bars will work best for you is to sit on the Spyder the way that you would be riding and close your eyes and then place your hands where it would feel the most comfortable. Now open your eyes and see where that is. If beyond the bars than a long reach bar would be the answer, but if shorter than the short reach bars would be better.
    Nov 2008
    Canada, Ontario
    I wouldn`t rely solely on the chart. I had to change my handlebar to the shortest reach to be comfortable. try it for yourself and then be mentally ready to change it after you`ve used the bike for a little while.
    J
    2018 F3 Limited black, dark
