Results 1 to 3 of 3
    Mar 2019
    Fla/NJ
    Default belt tension adjustment
    2015 f3-- If adjusting belt tension is the adjustment done with the belt tensioner resting on the belt? What is the correct reading ? Wheel on the ground or off? Confused new guy
    Sep 2009
    La Valle, WI
    I do it off the ground. I'm at 160 ft lbs. The tensioner doesn't matter. So little pressure it doesn't change specs ethier way.
    2018 F3 Limited , Oxford Blue
    Quote Originally Posted by honsfun View Post
    Tension needs to be done with the Adjusters at the AXEL …. depending on which swing arm style …. look in your owners manual …. it should show you how..... I use a KRITKIT device and do it on the ground ….. I suggest you get the tension where you want it. ( I highly advise much lower than what BRP has it at - for less to no Vibes ) … then after it's on the ground check it again and record the change..... Use this reading to check it in the future. Since it will be = to off the ground - you won't have to lift anytime you want to check it..... to me this makes more sense. …...good luck …. Mike
