Results 1 to 8 of 8
    Mar 2018
    north georgia
    Default headlight dimmer not functioning
    i installed led bulbs and after everything buttoned up tried the dimmer function, i can hear the shutters click but the lights stay on dim i can see it try but it doesn't make it. i have seen posts of this problem here but unable to locate it now HELP haha if you can, thanks Ray
    Jun 2010
    Las Vegas
    Ray try removing the cover and see if the shutter functions with the cover off. You may need to cut a small notch in the cover so you can leave the ballast out of the covered assembly. Having all of the wires and ballast inside the cover can cause the shutter to stick.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Quote Originally Posted by SpyderAnn01 View Post
    …. Depending on who made the LED unit …. if you had to stuff wires into the headlight ( that was not made for all those wires ) one or more of them may be preventing the shutter from functioning …. It ia actually a fairly common issue and easily fixed ….. Mike
    Dec 2015
    Oakley Utah
    The 'dimmer' is actually a solenoid operated shutter that blocks the top half of the light reflector in 'low' mode. The LED bulb kit involves additional wires and a bulky ballast that need to be tucked away carefully before closing up the housing in order not to interfere with the shutter operation.
    2014 RTL Platinum
    Mar 2018
    north georgia
    Thanks for your responses, errrr i'll take it apart in the morning thanks again, Ray
    May 2014
    Courtenay,BC,Canada
    I replaced headlights to LED but after one day the HI Beam 20 amp fuse was blown. Found the left headlight shutter not working. Found a shorted transistor on the little circuit board in the headlight assembly.Hope I don't have to buy the whole headlight assembly for one shorted transistor.
    May 2014
    Courtenay,BC,Canada
    Replaced the transistor -Now the fuse stays good but no shutter action on that headlight. Swapped the little circuit board between the left and right headlight and the snag stays on the same side. Guess the shutter mechanism is fu fued. Guess I'll ride with one hi beam if I need it. At least I can wink at the one eyed vehicles on the road.
    Nov 2018
    Claremore, Ok.
    When I installed LED headlights I left the back cover off, cable tied the ballast on the side and everything is still clean and happy.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
