Results 1 to 3 of 3
    Sep 2019
    Chesnee SC
    Default Top Case Harness part number help
    I need the harness that connects the top case into the main wiring of the bike. I believe it's called a cargo harness, but I've ordered and received the wrong part twice now. This is the harness that connects to the two wire connectors on the bottom of the top case of a 2016-2017 F3 Limited. It also has a small connector for the aux USB power jack in the top case. The harness should have a part number tag on it under the passenger seat. Help!
    Mar 2013
    This is what is on the tag on my 2018 F3L
    CB-PWB-HRN-36
    M213399
    POWER HARNESS
    Looking on line I was not able to find it, and I did not find that harness on the parts diagram at cheepcycle parts.
    Good luck!
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Sep 2019
    Chesnee SC
    Duh! I removed a plug from a harness connector on the latest part i ordered from Bike Bandit and it mated perfectly. The plug had green nipples on it, so I didn't realize it was, in fact, a plug. Top case lights are all working now!
