Results 1 to 22 of 22
Thread: M2 Shocks
    Apr 2019
    Florida
    Default M2 Shocks
    Installed a set of M2 shocks on my 2019 F3 Limited yesterday. Spent most of the time removing and installing body panels to gain access to the top mounting bolts for the shocks. Probably won't get a chance to test ride for a few days. I hope they perform as good as they look. A shout out to Marcus (M2 shocks) for being available to answer my questions, even on Sunday.
    2019 F3 Limited , Big Bike Parts full size pedal Black Metallic
    Sep 2019
    South Dakota
    Quote Originally Posted by rdkarl View Post
    Sweeeet! don't forget to give a riding review! I guess I should head down to the Post Office myself to see if I have a package from M2 also, tracking said today?
    Mar 2013
    Did you keep, or remove the air bag?
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Jun 2016
    indpls in
    leave i only have like 5 psi in just to keep from hurting the bag
    Mar 2013
    Quote Originally Posted by fatboy View Post
    I did not know that you can adjust the air pressure with the auto air ride. We have the 2018 F3 limited.
    Apr 2019
    Florida
    Quote Originally Posted by PW2013STL View Post
    I kept the air bag.
    Sep 2017
    Durham,Maine
    Oh, there's a way you can adjust the air in the auto ride, and depending on witch shock he got, he may want to switch it over to a manual fill system! I hope he talked to the guys at M2 and run that by them, don't want the two systems fighting each other!
    2012 RTL , Pearl
    Sep 2017
    Durham,Maine
    You have done just what I want to do to my RTL Let us know what you think when you get her out of the barn!!!
    2012 RTL , Pearl
    Feb 2020
    Arizona
    Did you have to loosen any of the settings when you installed? Video from M2 shows loosening the collar in order to compress the shock during installation... seems to me like that would remove the custom presets from the factory
    Apr 2019
    Florida
    No I did not have to loosen the preload collars to install the shocks, but the preload does not come factory preset per se. They have to be adjusted to achieve the proper ride height. It is detailed in the included instructions, and Marcus was always available for any questions that I had.
    Active Member DougE's Avatar
    Dec 2019
    Cambridge, Ohio
    I loosened them on my RT. I thought it was easier to put them in. You will have to adjust them anyway to set your ride height.
    2013 RTS
    M2 Shocks
    Yokohama Advan Fleva 205/55/15
    Vredestein Quatrac 5 175/55/15
    Viair 97
    2013 RTS , Quantum Blue
    Feb 2012
    Spring City,Utah
    SO RDKarl, It has now been 6 months since you installed your new shocks. What do you think?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Sep 2014
    USA
    That picture of the front shock from the original post does not look to be installed correctly. Its upside down..
    Feb 2020
    Arizona
    Thanks, was it easy to find a pre / post reference points to adjust the ride height? Spyder won't actually be here until this week so I can't look for myself.....
    Sep 2014
    USA
    4.5 inches off the ground when measuring the front end. You will still need to set the dampening to suit your riding preference.
    If you go to M2 web site you can down load the installation instructions and he has a video on you tube.
    Jul 2019
    AL
    thinking of getting a pair,let me know what you think
    Active Member T.P.'s Avatar
    Oct 2016
    APPLE VALLEY, MN
    I Agree! Looking at the install instructions on the M2 website it does appear they are installed upside down
    for a Spyder but not for a Ryker.
    T.P.
    Apr 2019
    Florida
    I'm very happy with the shocks, compared to the stock setup. The Spyder feels much more planted, it tracks better through the corners, and it has an overall plusher ride. In combination with the Baja Ron swaybar, it also has reduced body roll in the corners.
    Apr 2019
    Florida
    Marcus mentioned that the shocks could be installed either way, but he felt that adjusting the preload was easier with the shocks oriented the way they are in the picture. I did try the shocks installed with the preload adjusters on the bottom, and I felt that Marcus was correct. After looking at them installed both ways, I feel the present direction looks better to me also.
    Feb 2020
    Arizona
    placed an order for a set over the weekend... can't wait to get them!
    Oct 2016
    APPLE VALLEY, MN
    Got my M2's yesterday and Installed today, going on a 98 mile loop tomorrow
    Mine are mounted opposite from rdkarls (above) and I have red coilover springs
    I have the 1st set of the new Pro Street Line
    T.P.
    Oct 2016
    APPLE VALLEY, MN
    This is a copy of my Sunday ride report from the other F3 area.
    Ride Report on my M2 Shocks. Just got back from a 105 mile test ride with the new M2 shocks that I installed yesterday, Rode from Apple Valley over to Prescott Wisconsin and down WI35 and crossed over to Redwing MN. That section (22 miles) has a bunch of hi speed curves that I normally ride at 10 over, Today hit those at 15 over when safe to do so. Stopped for a pop in Redwing and then headed toward Vasa MN and County 7 Blvd. That section has an 8 mile stretch of 30 mph curves, and thats when the rain started. Spyder rides flat into, through and out of the curves. Like other M2 shock owners have said "like they are on rails" Yep that's it. Curves that I always found myself pushing on the outside floorboard didn't need that today. MRS.T.P. who followed me on her Spyder said that everything seemed way smoother throughout all of the curves. The shocks come well packaged showing me that Marcus really cares for his customers and his products.
    These M2 shocks are GREAT! OUTSHOCKING! the Competition every day
    If you need to talk to me, Please PM me a cell# These are installed on a 2017 F3T PB1 from PITBULL
    T.P.
