Results 1 to 6 of 6
    May 2016
    Noblesville, Indiana
    Default For those of you with an Atlas throttle lock...
    Because I care so much for my fellow Ryker ryders, I wanted to pass along this tip.
    Last summer on a trip from Indianapolis to Moab, Utah, I lost the little clear pad of my Atlas throttle lock rendering the throttle lock useless. As I had thousands of miles yet to go, this was a big problem.
    So what's a guy to do?
    In a Nacgyver moment, I found a section of rubber fuel line and I cut off a 1/2 inch section and then split that half inch section into two 1/2 moons. See picture.
    With one of those Half Moons, I trimmed it up a bit and super blueed that in the place of the clear pad. The throttle lock then worked much better than the original. I set it and forget it. And it holds speeds for miles and miles.
    Inquiring minds need to know....
    Ryde on.
    Default Well done...
    Nicely done.. Where there's a will there's a way... glad you found it. Good to know for those using the throttle lock...
    ​2012 RS sm5
    Member saralyn15's Avatar
    Feb 2020
    Iowa
    Im looking at getting an atlas throttle lock. after doing some budgeting, i was looking to see if i can find it cheaper on ebay. Come to find out, they have a top kit and a bottom kit for a quarter of the price. Which kit do you suggest for a 2019 ryker ralley?
    2019 Rally , Yellow and black
    Aug 2007
    Greeneville, TN
    Very interesting! I would very much like to see pictures of the finished product.
    Jan 2015
    Indianapolis, Indiana
    I may be wrong but I believe what you're looking at is only the Plastic inserts, allen wrench, alcohol pad and a couple of screws, not the unit itself. For about $25 it's called a replacement kit.
    May 2019
    Washington
    The Atlas has been 135.00 everywhere i have found it.
