Results 1 to 5 of 5
    Jul 2019
    AL
    Default acc plug in for a 2019 rt
    went thru the service book and cant find a acc plug setup.Bought a corbin heated seat and hooked it up to the f4 trailer fuse as the instructions said to do,but get no power to the seat.The instructions are for a 2010 rt,think the fuse box has changed,just need to know where a switched wire is that can handle a 10 amp fuse,thought i could use the extra gps connect but that will not work.Any help would be appreciated
    Active Member MSa1956's Avatar
    Mar 2017
    Myrtle Beach, South Carolina
    Why dont you put an accessories block in so that way it comes off the battery instead of trying to find a circuit with enough amperage.
    Add On’s
    2017 Pearl White RTL
    SPYDER RAM Multi Mount
    Ram Mount Drivers cup holder
    Ram Mount passenger Cup Holder
    TRICELED Bar/Circle
    Brake Light/RGB LED
    Ground Effects Lighting
    Airhorn/compressor
    LED Head Lights
    LED Fog Lights
    K & N Air filter
    Two Brothers SR1
    Cat Bypass Pipe
    Easter Beaver Accessorie block
    USB pwr plug
    Removable hitch assembly
    Aug 2013
    SF Bay Area
    It's not safe to tap into just any power wire as it could end up causing errors in the system. Best is to use a fuse block like MSa1956 recomends to power accessories. I use a Neutrino Black box but there are simpler fuse blocks that work the same. Tap into a hot wire, like the front fender light, to trigger the relay.
    2021 F3 Ltd , Magna Red
    Sep 2017
    Durham,Maine
    you want to make sure it's a keyed power connection you tape into
    2012 RTL , Pearl
    Nov 2018
    Claremore, Ok.
    (2015 RT-S Special Series) I took the frunk off to install Baja Ron's Shock adjusters. Cleaned out/off the radiators, and then I was looking at the fuse boxes. Noticed that the black box that holds the fuses has plastic clips that hold it into the black box bolted to the firewall. Being the Curious George that I am I unclipped it and pulled it forward a little. Hey! There's two 1/2" x 1-1/2" slots that go thru the firewall and you can see the radiator bottle behind there, and it's easy to slip wires up there and route them under the headlights to the front handlebar switches or anywhere else you might need to go. There's enough room behind the fuse wires to T-Tap into the wires for whatever light system needed. There's also the main wire terminal from the battery that I'm going to use for the electric plug for heated clothing or the jump start plug.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
