Results 1 to 6 of 6
    May 2019
    Kelowna BC
    Default 2010 RT SM5 no clutch pressure
    I have 65,000 km on my 2010 RT SM5, went out all day Saturday and had no issues. I went to move the RT today and there is zero resistance on the lever and the clutch will not disengage and the bike stalls when put into gear. There is no fluid apparent on the ground or on any of the bodywork. This happened suddenly.
    Sep 2012
    Stetson, Maine
    check your fluid level. It is probably low or out. if it is low, adding brake fluid might work. if not you will have to bleed your clutch line. I have to add a little fluid every summer. You also could have a damaged O ring in you clutch area. bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Jul 2010
    Las Vegas, NV
    Add dot 4. Probably the O ring in the slave cylinder. Replace.
    Joe Meyer
    Default Start with the fluid
    Have had issues like this , not loosing it all, but found the fluid was all but gone. Filled her up and all was good except for the fact is ran out of fluid and yet none spilled out..🤔 So a quick check showed the leak was from the slave...
    20170314_122917.jpg pop this cover and check 20170314_122933.jpg If you see this you need new o rings...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Very Active Member Lin's Avatar
    Apr 2013
    Somersworth, NH
    It was quickly apparent with my 2011 as well. Take a look at my post about the condition of the fluid.
    When was your clutch fluid last replaced?
    https://www.spyderlovers.com/forums/...M5-Clutch-Luck
    2016 RT-S Special Series
    2016 RT-S Special , 2 tone black
    Durham,Maine
    Gene, if he has air in there wouldn't he have to bleed the line out???
    2012 RTL , Pearl
