Results 1 to 11 of 11
    Nov 2015
    Cypress
    Default Color code of brake light wires....
    I have a 2016 F3T that I have the connector undone on one side at the rear near the taillights. I'm trying to tap into the ground and the brake light wire. I tried a test light at the connecter but seems it did not make contact with connectors. What is the color of ground and the color of the brake light wire?
    Buckskin
    2016 F3T , Pearl White
    Active Member BernardD's Avatar
    Mar 2017
    Geneva, Switzerland
    Hi,
    Not sure for the F3T but on my RTS the brake is black (for ground) and Orange (for brake light wire).
    I would presume that the cabling is the same on all Spyder (but I may be wrong).
    Ride safe!
    Jul 2011
    Mitchell, Ontario, Canada
    The brake light wire is white. The grounds, there are 2 of them, are black.
    Mar 2017
    Signal right is brown/yellow to yellow on the connector.
    signal left is gray/pink to yellow on the connector
    tail is orange on both sides of the connector
    brake is white on both sides of the connector.
    black is ground on both sides of the connector
    pic from my installation of super bright surface mount T3 leds.
    Details ON MY PAGE >click here<
    Nov 2015
    Cypress
    Been away for a few days, but appreciate the color code info guys.
    Buckskin
    Oct 2020
    Dayton, Ohio
    Quote Originally Posted by Rattlebars View Post
    Rattlebars,
    Is the white wire the brake light wire on all spyder models? I am trying to connect my led lights with the brake light fixture and wanted to be sure as to which wire I needed to tap into.
    Thanks.
    Feb 2019
    Portland, Oregon
    While on the subject of wire colors, I'm wanting to add a LED second back-up light without having to remove the top trunk, if possible. Anyone know the color of the wires going to the reverse light and can they be seen under the passenger seat? i suspect there are only 2 and one is a ground (black?). 2017 F3L.
    Oct 2011
    Kalamazoo, Mi
    Back up wire is PK/BG
    2018 F3-T
    2018 F3-T , Pearl White
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by IGETAROUND View Post
    Thanks....is that PINK and what is BG?
    Oct 2011
    Kalamazoo, Mi
    Main wire color is pink/ beige stripe
    2018 F3-T
    Feb 2019
    Portland, Oregon
    I was thinking it might be beige, but wasn't sure. Thanks for helping - you're ending the year helping a fellow Spyder rider.
