Results 1 to 7 of 7
    Jul 2019
    AL
    Default help in finding a part
    getting ready to take the trunk off my 2017 f3 limited,and i see there is supposed to be a cover that goes on in its place,can you tell me what it is called so i can look it up..... Thanks Lee
    Jul 2019
    AL
    i searched the forums and think i found the part #
    Default You think... 🤔
    From the parts list at cheapcycleparts.com it shows a tail faring package for the T at $169.99 that looks to replace the trunk for the LTD. Could that be it...??
    ​2012 RS sm5
    Jul 2019
    AL
    that's it,thanks
    Apr 2019
    Florida Swamp
    The storage compartment in the tail fairing is very small and almost useless except for a few small items. You can get a small tool kit and maybe a small first aid kit in there. That is about all.
    2019 F3-S , Black & Silver
    Active Member AVBIZ's Avatar
    Oct 2019
    Roswell, GA
    Curious how long it took you to swap to the tail cover. That’s a big selling point for the 2020; if just an easy swap then the 2019 looks appealing as an option.
    Jul 2010
    Las Vegas, NV
    There are 2 brackets that have to be removed to put the cover on in place of the top box. When you open the box, remove the rubber mat, remove the 2 screws. What those screws go into is what needs to be removed. You need 2 pushpins, too. Takes 10 minutes, one Torx 30 screwdriver. The metal fasteners at the rear of the cover might need to be installed.
    Joe Meyer
