Results 1 to 14 of 14
    May 2019
    Texas
    Default Help needed please
    Hello Spyder community. I am in need of some help. I have a 2017 F3T and recently my left saddlebag would not open. It feels like nothing is engaging the latch. I have tried everything. Finally took it to dealer and after their tech had to call into BRP they finally got it. I picked it up, it worked, so I headed home. Got home and went to open it up and nothing. UGH! Back to the dealer and after a bit they give me the ol we cant get it open so sorry for your luck bit. They said they created a “case” with BRP. Well, BRP said there is nothing they can do either... since I am 1 month out of my warranty. So all of that to ask if anyone knows a way to get it open? They are the factory saddlebags that come on the F3T. Any help is greatly appreciated.
    Feb 2019
    Portland, Oregon
    Have you taken it to a locksmith? That's the first thing I would do.
    May 2019
    Texas
    I have not tried that approach. The locking mechanism is working fine. It’s when it is unlocked it doesn’t release the door when opened which makes me think it is internal with the latch itself.
    Florida Swamp
    Look at the hinges and see if there is a way to maybe cut the hinge pin end off with something like a Dremel tool with a cutoff wheel. If you can cut the pins and get them out of the hinges, you will be able to open it from the hinge side and not damage the latch any more than it already is. Once you get it open and repair or replace the latch, the hinge pins will be simple enough to replace.
    2019 F3-S , Black & Silver
    My 2014 RT had similar issues early on. It required an adjusting of the cable and that fixed it.
    Default Little checking
    If the proper adjustment does not help you may need a new latch system. I am not familiar with this but from the parts list on cheapcycleparts.com the latch system is $104.99 and the control unit is $32.99 and it could be one or both.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    May 2019
    Texas
    I will look into this idea. I did think about this earlier but if I could pop the hinges out of the bottom that I could pull the cover from the bottom out enough that I could possibly get my hand up in there and release the latch.
    May 2019
    Texas
    I would be perfectly fine with this as an option as well. My problem is the dealer is telling me all they can do is break it open, which leaves me buying a new saddlebag for that side. It just amazes me that the dealer has no idea how to solve this. Ugh! Customer service these days is out the window and piss poor at best.
    May 2019
    Texas
    Chupaca, any idea where I can find instructions for an F3T on how to adjust the cable myself?
    Jul 2010
    Las Vegas, NV
    There is no cable on the F3T.
    Remove the rear seat. Remove the 2 pushpins, remove the fender cover. Use a small punch, and remove the latch pin. Remove the latch. Use needlenose pliers to tug the arm to open the bag. Call me if you want me to walk you thru it. Joe
    Joe Meyer
    May 2019
    Texas
    Thanks Joe. I will try this out in the next day or so and let you know how it goes. Do you think i need to have the latch replaced or is there some other type adjustment that can be made to prevent it from happening again?
    Jul 2010
    Las Vegas, NV
    Once you get it open, see if it is broken, or just slipped apart. If so, put it back together and test it. You can push the two catches in and test it by pulling on the lever. If they pop open, close it and try the lever. I’m in Texas today. Houston area; Pearland. If you are nearby, bring it over!
    Joe Meyer
    Oct 2017
    Las Vegas, Nevada
    Quote Originally Posted by Spydrdan View Post
    You said your Spyder is one (1) month out of warranty. It sounds like you may have brought this problem to the dealer BEFORE the warranty expired and they didn't get it fixed. If so, you are still covered until they DO get it fixed. The Federal Trade Commission (FTC) says: "if you reported a defect to the company during the warranty period and the product wasn't fixed properly, the company must correct the problem, even if your warranty expires before the product is fixed." See https://www.consumer.ftc.gov/articles/0252-warranties
    2017 RTS , Blue
    May 2019
    Texas
    Unfortunately Johnsimion I did not notify the dealer before the warranty expired. It actually happened after. My biggest complaint is how they handled it, the dealership and BRP. I am more than willing to pay someone to fix the problem but what I was told was they needed to break the saddle bag in order to get it open. Not “hey here is a problem I haven’t come across before. Let’s figure it out”, because there is never a one time only problem. I cannot imagine that is truly the case after receiving the helpful information from some of the guys above on how to get it open. Joe’s response seems to be extremely detailed and I have no reason to doubt him. After all he did create the wedgies, which I have purchased, I just have not had the chance to follow his instructions as of yet. Thanks for the suggestion though. Finding out everyone is super helpful in this Spyder community.
Tags for this Thread
