What experiences have you had with Lithium Batteries?
What experience have owners had with Lithium Batteries? Are they better? do you need a battery maintainer for them? Does it need to be a special maintainer?
SpyderLovers Sponsor
I was told by some experienced people that I trust, not to go with a lithium. Granted, there have been some issues with them. But being the kind of guy I am, I didn't listen to them. This is the battery I got and I am EXTREMELY pleased with it. I think it is awesome!
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It is much smaller than the OEM battery so I don't have to wedge it into the very tight space allowed. It weighs almost nothing and delivers more power than the OEM battery. Lithium is supposed to last longer too. Have only had it for 6 months so can't say there.
There isn't anything special you need to do for it except you'll need a good Lithium battery charger. Do not use a charger that is not designed for lithium batteries.
I've had a LiPo battery in my old, slow V-Max for 7 or 8 years. Weighs nothing, works every time. I do have the proper charger though. I had thought about one for my but got a regular battery instead as previous discussion on this site was not too positive.
Lew L
I don't understand. If the LiPo battery needs a special charger, how does the vehicle charging system designed for a conventional battery work ?
If the battery is dead, can you jumo it using a conventional jump pack or jumper cables to another vehicle ??
IBA #47122
2020 RT Limited Asphalt Grey
This explains some of the questions. I think it's just a matter of time until vehicles switch to lithium batteries. The cordless tool industry has made the switch and they seem to be a huge improvement.
https://enerdrive.com.au/2017/11/29/...-acid-charger/
Reason: Fixed unneccessary URL attempt that garbaged the link! :/
2018 Spyder RT Limited
Asphalt Gray
Can Am Passenger Armrests
Can Am Comfort Seat
Spyder Accessories Floating Footpegs
Utopia Driver Backrest
Bajaron Sway Bar
Sena 20s Bluetooth
Lidlocks Helmet Holders
F4 Tall and Wide Tinted Windshield
Fobo Tire Monitor
Lamonster Spyderdock Cell Phone Holder
Sheepskin Seat Cover
Drink2Go Cup Holders
Magic Mirror
Can Am Trailer Hitch
Missing Belt Guard
Wish List - LED Headlights and Fog lights
Ron, How long have you been using this battery in your ride, had any issues??
re-read?
Those who say " I can't" will always be right.
I've been running this battery since March of this year. About 6 months. Zero issues. Though I had zero issues with my previous AGM battery until it gave up. The lithium has a number of advantages over the AGM. Weight, (substantial difference. (I think it was 17lbx down to 3), CCA is much higher, (Don't remember the difference there). Smaller so it isn't such a tight squeeze. Previous AGM batteries swelled a bit when they went bad and were difficult to remove. I really like it.
This inquiring mind wants to know. If a Lithium-Ion battery can be put in a Spyder and the alternator keeps it charged, why can’t an alternator be put into an all electric car such as a Tesla rather than having to plug into an electric outlet?
2020 F3 Ltd
Spyderpops Bumpskid
Tesla and just about any fairly new Electric golf carts have had regenerative braking, which is where when the car goes downhill they use the momentum to generate electric which is then fed back into the main battery. An alternator used to charge the battery while driving would have to be the size of a doghouse to keep up with those batteries, it actually would be like creating a perpetual motion machine which is not possible yet.
Reason: spaces after punctuation... ;-)
: 2017 RTL ORBITAL BLUE
Thanks for the info. So using a Lithium-Ion battery in a Spyder would be constantly charged by the 1330 alternator? And the alternator would not over charge or harm the battery? Also, I guess a Lithium-Ion charger would not be needed as long as the Spyder was ridden year round?
2020 F3 Ltd
Spyderpops Bumpskid
Depends...
This subject has been around for sometime. I know that on the Twins those batteries did not fare well and they were not recommended by many. Now on the newer engines like the 1330, 900 and 600 they may work well as they are easier to start with less of a load. On the Rykers there is the added advantage of not having the DPS that is a heavy drain on the battery. Have not heard much on thier use on the newer engines but would imagine they will perform well. Just need to support them with some spacers in the battery box area....
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Originally Posted by Tenic
Thanks for fixing the link, I now understand.
So if I read this correctly, NO, you cannot use a LiPO battery with a charger designed for lead acid batteries.
Since most common vehicles (maybe airplanes are excluded) use lead acid batteries, switching to LiPO will require changes to the alternator/voltage regulator.
Am I correct ?
IBA #47122
Customer Support
Wonder if this is still an issue given probable advances in the technology.
2015 Pearl White RTL
Baja Ron Sway Bar
Russell Day Long Seat
Strobe Brake Light
Prior to my Spyder, I put one in my BMW R1200GS. As others have said, smaller, lighter, 4 battery terminals, etc. I was very pleased but I only had the bike for 1 year after putting in the LiIon so I don't know what longer term experience is like. Playing it safe I used a LiIon Battery Tender Jr.
The battery in my RT surprised me by failing with no warning. I could not quickly find a LiIon in the stores and I didn't want to wait for it to come from Amazon. I purchased a Duracell AGM at Batteries + Bulbs.
Rob
Rob
Reason: put subject quote before text to aid understanding...
2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
Something has to turn the alternator in order to generate electricity. In a gas engine vehicle it's the engine that does that. An all electric like the Tesla has no engine to turn the alternator.
I have a 2008 GS. The lithium battery is working fine so far. Though it is curious that the charging system is certainly not optimized for this kind of battery. We will see how long it lasts.
From having hand tools with them, my only fear would be that when they get ready to give up it's like turning off a light switch! It will be interesting to see what will happen, guess you may want a jump pack ready!
My hope on these is that they have the necessary voltage/amperage adjustments built into the battery, kind of like the newer cell phones. If they require some special modification of normal automotive voltage, and are sold as drop in units, then this must certainly be the case, right? Otherwise the very real possibility of the LI battery exploding (reference Tesla, Vaping units, certain cell phones I.E. Samsung 7 banned from commercial aircraft)
h0gr1der
Lion batteries have a built-in recharge counter with a limit on the number of recharges. When it's reached, no more charging. That may be what you have encountered. I don't know if Lion vehicle batteries have the same thing but I suspect they do.
Interesting ….. if this is accurate, that number is must be hugh. Doesn't the alternator ( or magneto ) recharge the battery almost constantly ????? ………… or am I missing something ……. Mike
I think he is referring to charge cycles. So you'd get just 1 charge cycle per ride (start to stop. Ignition on to ignition off). It would not count an additional cycle until the charger (whether it be a static based or vehicle charging system) was disconnected/turned off and restarted again.Though I don't think static lithium battery chargers have a 'Trickle Charge' cycle. If this is true, there would be an automatic shut down when full charge is reached. If the charged came back on at some point, another charge cycle would be added to the count.
Did we ever get this sorted out ?
I've looked for references to a recharge cycle counter on the Lithium Polymer batteries, but can't find any.
This could be true, but as stated, that means you could be out in Utah one day, and start your Spyder at camp and Boom.....No warning, No battery.
Shouldn't there be some type of warning associated with that ? Sort of like when you start getting low on gas ?
I'm asking because I'm liking the possibility of the LiPo battery.
IBA #47122
I just did some searching. Here is a quote from Super B batteries web site FAQ page. https://www.super-b.com/en/faq
A Battery Management System is necessary for control and protection during discharge and charging. The BMS provides CAN bus communication of battery status ‘state of charge’ and alarms etc. It may also be used without CAN bus interface with just basic analog inputs and outputs for simpler systems.
In another answer they say the charging system must be modified. What that all means is a good question. They sell motorcycle batteries but essentially have no information what, if anything, you need to to do to use a LiPo battery in a motorcycle.
This page, https://www.lithiumion-batteries.com/, says Battery Management System built in. They also state 3000 - 5000 cycles. But what constitutes a cycle?
Here's another quote from https://antigravitybatteries.com/hel...rical-charging
Our lithium batteries will operate perfectly fine with the stock charging system in most motorcycles, powersports vehicles and automobiles. Where the problem can occur is when charging the battery with a standalone charger. Additionally if you have an aftermarket charging system on your vehicle, note that we cannot warranty the battery for use with aftermarket charging systems due to the fact that we do not test with these and some of these are not regulated as strictly as a stock/standard system found in a motorcycle, powersports vehicle or automobile.
To sum it up LiPo require special charging systems but they're built into the battery. There is a limit to how many times any Li-on battery can be charged. Beyond that the web sites are scant on information just as you say.
I bought into the Lithium ION Kool Aid when I had left my Ducati for about a year no charging, and it started right up. The Shorai battery is OE in my Ducati. I have since put a 6 volt in my 1981 Honda C70 with electric start no problems. I have one waiting to go in my 1959 Harley FLH which has been converted to 12 volt but is a generator system, shall see how that works out. I also have one ready to go into my 2003 Harley sportster. They weigh next to nothing, are smaller than OE, can get different sizes though. I get mine and chargers for Shorai from Battery Mart. I will change to them as I replace in all my bikes. The Shorai comes with sticky foam to take up excess space in battery compartment. The only thing is they hibernate a bit in coooold weather and sometimes need to turn lights on to wake them up. Who rides in cold anyway?
