Results 1 to 11 of 11
    Feb 2016
    France
    Default Plastic encapsulated nuts
    I need to remove the frunk to replace the LH headlight bulb (UK model)
    There are 2 bolts underneath that hold the bottom of the frunk to the chassis, they screw into plastic encapsulated nuts The bolts are not stainless just plain steel, one of the bolts is rusted into the nut, now the nut is just turning in its plastic holder, how am I supposed to get this bolt undone as there is no way of holding the nut. They do the same nasty trick on the inside of the front fender supports.
    I dont think derusting agents will help as you can't hold the nut with anything
    Anyone else had this problem
    Alex
    2014 RT Std
    Floor and Highway Boards
    50$ GPS connected to oem loom
    Trunk & Frunk Liners and lights
    Frunk and dashboard power outlets
    Front supension LEDS
    Cup holders
    Glovebox light
    Turn signal LEDs in mirrors
    12 volt coffee maker
    Passenger hangrip muffs
    Ignition lock light
    Windscreen wiper/ baguette holder
    If I wasn't so cleverI wouldn't need to be so good looking.
    2014 RT , Black
    Jul 2010
    Las Vegas, NV
    Yes. Split the plastic encapsulated nut. Remove steel nut. Replace with ss. Replace trapper.
    Joe Meyer
    Aug 2013
    SF Bay Area
    Why are you removing the frunk to replace a headlight bulb? Remove the mirrors, and side screws under the mirrors that hold on headlight frame piece. You also need to remove the side panels, (the ones that pop off). Then remove the big nut that holds the headlight adjusting knob so when you go to pull the headlight out, the cable comes with it. I think the black plastic covers on each top cornet of the frunk pop off. Make sure the headlight doesn't fall out when removing the 4 bolts for each headlight housing and carefully with the top bolts as they can fall down into the bowels of the bike never to be seen again.
    This is the headlight frame that needs to be removed.
    2021 F3 Ltd , Magna Red
    Mar 2013
    Flamewinger,
    I beleave the European models have separate high and low beams, and place the low beams in the spot where American models have for running/fog lights.
    Having put running lights in our 2014 RT I did remove the frunk to make it easier.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Quote Originally Posted by PW2013STL View Post
    Flamewinger,
    That is true for our Aussie & Kiwi Spec Spyders too!! Hi-beam where your North American Hi-Lo headlights are, while lo-beam is where your running/fog lights go! None of this 'shutter switching' stuff for us.... But it does make fitting LED headlights cost a bit more, AS WELL as making it pretty much necessary to remove the Frunk to change the lo-beam globes!
    Last edited by Peter Aawen; 10-31-2019 at 07:08 PM. Reason: globes, not blobes! :/
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    Not sure how you're supposed to split the rusted nut when you can't get to it, it's up inside the plastic. I ran into the same issue when replacing the left side hard bag on mine. Both the top nuts were seizes with no way to get to them. Ended up having to drill them out and replace with something different.
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
    Jul 2010
    Las Vegas, NV
    On a RT, the right fog light/low beam is very easy. Use that to practice on. The left one has the air intake snorkel slowing you down, but the frunk does it have to come off. Use a long flat tip screwdriver to release the cover. Remove it out the top. Unscrew the bulb, then disconnect the wire. Connect new bulb, install, and replace the cover. I use a length of wood dowel to pry the intake out of the way. It helps to trim the lower tab a couple of mm.
    If you can’t get at the lower nuts, you might have to drill it out and replace.
    Joe Meyer
    Durham,Maine
    Hate to say it, but you may be able to drill the head off the bolt or screw then when you get to where you can get your hands on that nut, have your way with it!!!Good Luck!!!!
    2012 RTL , Pearl
    Feb 2016
    France
    On uk model low beam is in the frunk only high beam is in the top, l/ h low bulb gone air duct is across back of bulb cover. Typical BRP Cock up
    2014 RT Std
    Cup holders
    Glovebox light
    Ignition lock light
    2014 RT , Black
    Feb 2016
    France
    If only you could turn the bike upsidedown
    2014 RT Std
    Cup holders
    Glovebox light
    Ignition lock light
    2014 RT , Black
    Feb 2016
    France
    Managed it now, remove bottom plastic plate you can see the nut, squashed plastic outer and screwed bolt in, wd40 unscrew till it starts tighten repeat operation about 50 times and it s out replaced with stainless steel bolt. So easy with frunk off, but for bolt problem, frunk off in less than an hour
    2014 RT Std
    Cup holders
    Glovebox light
    Ignition lock light
    2014 RT , Black
