Results 1 to 14 of 14
    Jan 2019
    Kansas
    Default How to secure cargo in tow behind trailer?
    Hello,
    I just purchased an Aluma MC trailer that I will pull behind my 2014 RT. The cargo area is totally naked, all aluminum. Any ideas how to secure the cargo inside?
    Thank you.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by gianfri View Post
    Hello,
    Thank you.
    What are you concerned about?
    2014 RTL Platinum
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    I have an Aluma also, and the beauty of this trailer is it's versatility. Are you carrying a bag of clothes and a tent?
    Or maybe it's a new rear tire and a box of tools. Try to make your items support each other. Also there are lots of different
    kind of shower rods and cargo bars and such that can be used also. Juist a little imagination goes a long way.
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    Dec 2015
    NE Ohio
    I got 4 fruit boxes from Sam's Club. Cut them up so they make 4 short height partitions so the cargo doesn't slide around. Easily removable for bigger loads. Cost: $0
    Jan 2019
    Kansas
    I don't want my cargo to bounce around when the trailer is not full, which will happen most of the time (for example, if I have only a couple of bags). Things inside the bags may brake.
    Northern Kalifornia
    Cardboard boxes will do the trick. Not expensive, easily replaceable, can find them anywhere.
    Dec 2015
    Oakley Utah
    Bouncing is a function of the suspension. I don't know of a,way to fix that with any kind of restraint system unless you create one using ratchet straps and tie downs.
    2014 RTL Platinum
    Jun 2010
    Las Vegas
    Pack it full and you won’t have to worry
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Northern Kalifornia
    I invested in a couple of HF mover's blankets to lessen the effects of bouncing. Helps a bunch but doesn't stop it.
    Always worked for me!
    And while I haven't needed to do it in a trailer behind a motorcycle yet, I have used 'seat belt style cargo nets' in our off road/expedition trailers before... All they need is a fixed eye or seat belt anchor in the 4 corners, click the cargo net in, tighten the tension locks, & nothing's moving unless you want it to!
    Dec 2015
    NE Ohio
    Cargo Net attached to the corners, need to add eyelets. Put the eggs and breakables in the trunk. Anything in the trailer will be shaken and stirred.
    Jul 2015
    Danville, KY
    Also keep in mind if it’s bouncing that bad to lower the tire pressure. Don’t need to run 30+ psi (just an example)
    Dec 2015
    NE Ohio
    Cargo blanket over everything sounds like a good option. How about a weighted blanket for more pressure?
    Jul 2015
    Danville, KY
    Quote Originally Posted by KosherKid View Post
    Over thinking it a little bit. Just proper planning of placement in the trailer, right amount of air pressure in the tires, and some cheap egg crate foam if you find it necessary to ease your mind on those objects and haul ace down the road
