Results 1 to 13 of 13
    Active Member Stangman35's Avatar
    Jun 2016
    Ladoga,Indiana
    Default Any recommendations for a hitch for 2019 F3 Limited
    Looking for recommendations for hitches , I’m looking to get a small trailer to haul camping gear. I’m hoping to go on a trip or 2 next year.
    Sold - 2021 RT Limited, Petrol Blue, trailer hitch.
    Traded in - 2019 F3 Limited, Blue/Chrome: with
    Baja Ron swaybar, 19” tinted Freedom Windshield, Lamonster LED headlights, IPS Fog Light Kit, trailer hitch, Lamonster Mirror Locks, Ultimate TallBoy Seat.
    Sold - 2014 Time-Out Camper
    traded in - 2017 Kawasaki ZX14R
    Sold - 2018 Honda Goldwing Tour DTC
    Sold - 2017 Indian Roadmaster
    Traded in - 2016 F3T
    And a couple hundred other bikes over the years!
    Mar 2013
    Maumelle, AR
    Your best bet is getting a BRP hitch. It comes with everything you need to tow your trailer.
    2020 RT Limited , Chalk
    Northern Kalifornia
    BRP, best choice. I've seen photos on this site of aftermarket hitches that have failed. Remember, the hitch attaches to the swing arm and therefore takes a hell of a beating. That beating will also transfer through the coupler and the trailer tongue to the trailer and its contents. So, pack appropriately and don't pop a Pepsi immediately after you stop and take one out of the ice chest.
    Jul 2011
    Mitchell, Ontario, Canada
    It depends on your skill level. A kit from BRP is your simplest option and it's a complete option. Also the most expensive. If you have good mechanical skills. You can buy a good aftermarket hitch, mudflap, hitch ball, wiring harness. All as individual parts, from several vendors. There are multiple options for each part. Some are not as good as others. You will save a few dollars.
    2018 F3 LIMITED
    Active Member Spider-man's Avatar
    Mar 2017
    San Antonio
    I have this one, love it. High quality, solid, and much less costly than BRP.
    http://bigbikeparts.com/templates/pr...4&GroupGuid=78
    formerly pman2011 YIRYDE's Avatar
    Sep 2012
    Northern Virginia
    I have the BRP hitch on my F3-T which includes everything you need, wiring harness/control module, hitch, mudflap and hitch ball. The hitch is also easy to remove if you don't want to keep it on your Spyder all the time. I like the look of the F3 without the hitch and remove it when I don't use my trailer. I use the trailer for trips that are longer than 5 days which is a couple of times a year, I mount bags on the back seat for trips less than 5 days.
    [B]
    2018 Intense Red F3T (See About Me under My Profile for mods)
    2010 Timeless Black RT-622 Trailer
    2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
    2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
    Jun 2016
    Ladoga,Indiana
    I’ll probably go with the BRP unit just because it comes with everything needed and it won’t hurt the warranty. Iv been wrenching for 30 + years so that’s not a problem. Just need to shop around and find the best price for one. So far $569.99 is the cheapest Iv found for the BRP hitch kit.
    Mar 2019
    Ruidoso Downs, New Mexico
    BigBikeParts now make their trailer hitch for F3T/LTD for $299.95. I'm thinking about one...........but then there's the trailer I don't have.............
    2020 F3L; gone but not forgotten are all the good miles!
    Dec 2013
    Quote Originally Posted by McRuss View Post
    Don't let that stop you!! : The trailer can always come along after.....
    I'm sorry,
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Jul 2011
    Just so you understand. The BigBikeParts hitch is a good hitch. I have one that I had on my STL that is in the garage somewhere. It worked very well. But it is not complete for hauling a trailer. You still need wiring, mudflap and hitch ball. You will need to cut the mud guard on the F3L for clearance.
    2018 F3 LIMITED
    Apr 2020
    Edgerton,WI
    I have a 2019 F3L
    I did install the hitch from big bike parts- it stayed on for a 1600 trip. When I got home, I took it off and put on the BRP- far superior in quality- the hitch arm is supported by rubber chassis bushings- equal smooth ride-far better than the prior. You wanna play, you gotta pay.
    2019 F3L , Covid Blue
    Bossier LoUiSiAna
    Another vote for the BRP however the module can be troublesome. Earlier ones had grounding issues not sure if is completely resolved as mine had a blinker cut out & interfered with the rear blinker on the bike. Replaced with one from eBay https://rover.ebay.com/rover/0/0/0?m...2F183520738273 & no problems. Hitch itself acted as a crumple zone protected rest of bike when had an unfortunate incident.IMG_6302.jpg the blinker fault maybe from the incident but was issue in the module, the connections were undamaged.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Feb 2018
    NorEastern, Washington
    Quote Originally Posted by Stangman35 View Post
    The BRP hitch is stronger structurally than the Big Bike Parts model shown. I do think that the BBP model is adequate for the max load rating. The BBP's also doesn't look to have the nylon shim pads that the BRP model has for cushioning against the swing arm. You can always look around for a used one. I found a BRP hitch in like new condition for $25 and that included free delivery.
    Regards,
    Don
    2017 F3T , Triple Black
