Results 1 to 22 of 22
    Nov 2015
    Tinley Park, Il
    Default HELP fuel filter replacement
    Good Evening Everyone, Hope everyone is still out riding. It's chilly here in Chicagoland.
    Well I did my 19.000 oil change and replaced the air filter okay. Now I just replaced the fuel filter and before I put her all back together I thought I would try to start her up to check for leaks. When I turned the key on it seemed normal but nothing happened when I hit the starter button. The lights were dim and flickering like a weak battery or bad ground or something else electrical. Nothing turns over or tries to at all. Could I have loosened a connection somewhere on the air filter side or the around the fuel Filter.
    Thanks, Mike
    Not that I know of and I've changed my air and fuel filters multiple times. Check to ensure the battery terminals are tight.
    Mar 2013
    More likely just a bad battery. If yours is the original battery you got good life out of it. I had to replace my battery in our 2014 RT at 3 years. Most auto parts stores and all battery + stores have a load tester and can test your battery to find out if it's still good.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Nov 2015
    Tinley Park, Il
    Thanks, I got the bike 3 years ago and he said the battery was brand new. It may be due to replace the battery but I never had a battery go just like that. I've been riding it all summer. It sat for a few days while working on it ( oil change-air filter change and now the fuel filter). I had the gas tank to ground wire off for a while. It had a star washer on it and I could not find it when I hooked it up again. Thanks again, Mike
    INDIANA, USA
    Default Battery Test
    Did you get the battery tested? It's usually a pass or fail. .....
    ENJOY YOUR LIFE WITH A SPYDER
    Durham,Maine
    2012 RTL , Pearl
    Nov 2015
    Tinley Park, Il
    I have the Besy ?Green Manual and I cannot find a table of contents which would be helpful with over 1500 pages. Is anyone familiar with the manual? Thanks, Mike
    Apr 2015
    Tucson, AZ USA
    FYI - I have a 2015 RTL and two weeks ago my Spyder went from starting fine one morning to deader-than-a-doornail by the afternoon. No warning, no nothing. Tested voltage and cranking load and it's gone. I don't know what your problem is, but batteries can fail without warning. I also suggest you check your battery connections as well.
    Rob
    Nov 2015
    Tinley Park, Il
    Thanks, I will be doing that today. I have one of those pocket starters that I'm going to try but it is dead so I'm charging it. With the Spyder if I jump it and remove the jumper cables will it die or keep running. Thanks, Mike
    Quote Originally Posted by wmh9680 View Post
    if jumped it should stay running and charging. How long it runs will determine how charged the Battery is for the next start. If jumping from a car make sure engine is off.
    Nov 2015
    Tinley Park, Il
    Thanks, will do. Mike
    Nov 2015
    Tinley Park, Il
    Pulled the batt and she shows 13+ volts but I’m taking it in to load test it. Having the mirrors disc wouldn’t do anything would it. I also have leds with an off/on switch and a direct line to the batt to charge my phone. Still wonder about a loose ground or connection somewhere. Had problems like that on my virago and an old plow truck. Thanks, Mike
    Mar 2013
    You did say that you had the ground to tank wire off that had a star washer, but lost the star washer. Was the star washer over, or under the ground? Just thinking that the ground is not making a good ground connection. That is where I would start looking.
    Nov 2015
    Tinley Park, Il
    Thought I replied earlier but maybe not. I took the batt to the store and it had to be charged so they could load test it. It was fully charged a few hours earlier so I was guessing the problem was the batt. It was 3 years old. It came back dead so I will be looking for a new one. Any suggestions who/what to get. Maybe a forum sponsor. Thanks, Mike
    Nov 2015
    Tinley Park, Il
    I don't remember if the star washer was under or over at this point, all I know is I can not find it and have to go get one
    Apr 2015
    Tucson, AZ USA
    I got a Duracell AGM at Batteries+Bulbs because they are conveniently located for me and I've never had a bad experience with one of their batteries. It was a perfect fit.
    The best,
    Rob
    INDIANA, USA
    Default Battery
    + 2 for Duracell AGM ....
    Nov 2015
    Tinley Park, Il
    Well I just picked up my new batt at batts&bulbs and she turned right over. Sure will miss searching for a short or bad connection, NOT. Thanks everyone. I guess I’m used to older bikes where that was the norm. Thanks again, Mike
    Nov 2015
    Tinley Park, Il
    Well it never ends. I started her up b4 puttin the Tupperware back on to ck for leaks and all was fine but I noticed a cable wasn't routed right so I disc one side of the fuel line from the filter and when i hooked it back up I dn ck for leaks again and put the Tupperware back on and took her for a ride and I smelled gas so I had to remove the Tupperware again and found I needed to tighten one screw on the fuel line. I cn figue out how to attach the clamp on the filter so it is just hanging there (see pic). Anyone remember how both metal brackets go. Thanks Mike
    I'm pretty sure that on my '14 RT-S the bolt and nut that hold the clamp in your picture go through the hole in the frame that is immediately above the bolt head with the blue stripe on it in your picture. On mine the bolt is a Torx head that feeds from the inside outward and the nut is an acorn nut. I'm sorry, but I'm not pulling off all the Tupperware to confirm.
    Nov 2015
    Tinley Park, Il
    Thanks, I took pics before but I couldn't tell from them. I watched Doc Humphreys video but it is a little blurry. Great video though. Getting pretty good at removing the Tupperware. Problem is I only do it once a year and I forget.
    How much uummpphh does the K&N air filter give you. It seemed a little stronger on my brief ride.
    Thanks again, Mike
    Apr 2015
    Tucson, AZ USA
    The following are from my 2015 RT manual. See if this helps you.
    Rob
    Screen Shot 2019-10-17 at 9.34.29 PM.jpg Screen Shot 2019-10-17 at 9.35.09 PM.jpg
