Results 1 to 8 of 8
Thread: Swivel coupler
    Active Member CharlieIndia's Avatar
    May 2011
    Washington Pa.
    Post Swivel coupler
    Is it better to have a swivel coupler when towing a trailer behind your Spyder?
    Feb 2012
    Spring City,Utah
    you have a three track vehicle that is not going to lean, and a trailer that is a 2 track vehicle and is not going to lean, so why would you want a swivel hitch? Those are for vehicles that lean.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Quote Originally Posted by CharlieIndia View Post
    It'd probably be a good idea to use a swivel coupler for the trailer if you're planning on doing a fair bit of 'rough road/off road' towing, (cos 'fixed ball' type couplings generally restrict the safe working angles of the hitch... ) but apart from that scenario, I'd go with what Pegasus said above.
    May 2011
    Washington Pa.
    Okay, thanks that's what I wanted to know. Never towed on two wheels or three.
    I think what I used would be considered a " swivel coupler " …. I really hated the clunk, clunk, clunk, of the usual Ball type coupler …. Every time you stopped or started or slowed or accelerated it would happen …. no matter how tight the ball was in the coupler ….. So I decide to use a " tie rod designed for a Toyt. pk-up " ( any tie rod will work, but the smaller the better )….. I bolted a 3 x 3 x 3 in. piece of alumin. angle to my Tow hitch and drilled a 5/16th hole in it …. the stub part of the tie rod, bolts in using a Lok-Nut the part with the swivel is attached to the tongue of the trailer...… NO more clunking, when I tow it I have to check to make sure it's there …. because I can't by feel or sound ….. an added feature is - it's much more difficult to steal ….. Mike
    Sep 2014
    USA
    I use a swivel coupler. Found it much better than the stock straight version coupler. Less of the twisting affect from coupler to trailer. JMO.
    I put one on the trailer I built to pull behind my Goldwing. Took it off and sold it when I modified the tongue to pull it with my Spyder!
    Mar 2019
    NEBRASKA
    Had a swivel on my previous trailer for 2 wheel and took it off and use it on the RT622 now...just a great idea in any towing scenario.
    2012 RTL 14 RTS , Pearl White @ Pearl White
