Results 1 to 8 of 8
    Active Member Claire's Avatar
    Jul 2019
    Georgia
    Default 2009 brake line replacement
    Hi everyone.
    2009 GS spyder. I might have to replace brake lines. Any idea on what this might cost at a dealer?
    Thanks!
    Default Why...?
    Best I can see is about 3.8 hours at whatever the shop rate may be... parts I would get from cheapcycleparts.com as it is not a warranty issue and their prices are much better.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jul 2019
    Georgia
    Thanks for reply. I'm pretty sure its leaking from the black lines on both sides of the rear shock. I attached pic
    Jul 2019
    Georgia
    Another pic with fluid on garage floor directly under those lines
    Nov 2015
    Chardon, OH
    Quote Originally Posted by Claire View Post
    Where is the brake fluid reservoir on this machine - right above there and under the seat? Can it, instead, be seeping down from the reservoir due to a crack or cap issue, or something?
    Doug
    ”Freedom is not a loophole”
    Mar 2019
    France
    I agree - check up higher first - wash off the muck etc and press brake and have a look - its strange for pipes to go first unless damaged.
    2009 GS SE5 , Red (Ferrari Red :) )
    Durham,Maine
    Is you fluid in the revivor dropping are you having to add fluid? I am thinking you my have oil blowing back from the motor! Wash it all down and keep an eye on it to see where its coming from. Good luck
    2012 RTL , Pearl
    From the new info I would agree with checking the reservoir caps as they need to be installed with the vent to the rear of the spyder. I think they also have updated caps but mine leaked and ran a similar route.
    ​2012 RS sm5
