Parking brake actuator failure/does BEST warranty cover?
So the parking brake failed on me. Has anyone else had this happen, and if so did your BEST warranty cover it?
2020 Can Am Spyder RT Limited "The Comet #2"
Baja Ron Sway Bar
Passenger Armrests From Can Am
Wolo Big Bad Max Airhorn
Lamonster Top Cuff W/Ram Ball
Lamonster Power Plate
Tackform Phone Mount
Key Cover from Ebay
Lamonster Mirror Locks
Ultragard Cover from Lamonster
Top Grills from Spyderpops
Garage Door Opener from Spyderpops
3.5mm Extension from Amazon
Lamonster USB Cable Holder & Cable
Foam Grips from Spyderpops
Tricled Strobe Brake Light module
Tricled Bag Lights (replace reflectors)
Tricled Turn/Brake/Run Signals Rear
Tricled Floorboard Lights
Tricled Sequential Run/Turn Fender Lights
Tricled A-Frame Run/Turn Lights
Tricled LED American Flag Mount & Flag
Showchrome American Flag
Mine failed at 9,300 and a year and was covered under factory so B.E.S.T. should cover it for your $50 deductible.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
Thanks! Did yours lock up when it failed? As in it wouldn't disengage? I'm only at around 5500 miles.
Baja Ron Sway Bar
Key Cover from Ebay
My Spyder has been diagnosed with this, on the first go around they replaced the left switch pack, this time the actuator. It's covered under warranty, if you're on the extended warranty it will probably cost you a deductible, which is way less than it will cost to replace the motor. I wish they would have made a simple manual hand brake. What a PITA. Costing me valuable riding time.
h0gr1der
2018 RT Limited Blue/Chrome SE6 *Tri-Axis Bars*Adjustable Driver Backrest*175/55R15 Vredestein Front, 205/60R15 Vredestein Rear Tires*Baja Ron Front Spring Pre-Load Adjusters*Misty Mountain Sheepskin seat cover*Centramatic balancers *Garmin Zumo 595LM GPS*KOTT Grills*BajaRon swaybar*SpyderPops Alignment*Missing Belt guard*Magnetic Mirrors*Custom Rear Adjustable Shock*360° LED Headlights & Foglights*Progressive front fender turn signals
States Visited on Less than 4 wheels.
Exactly what I am upset about most!
Baja Ron Sway Bar
Key Cover from Ebay
GOS member (Girls On Spyders)
You can do the 12mm wrench thing while you wait for the dealer to obtain the parts -- this is what I did when mine started getting "sticky." Once the parts are in, schedule an appointment for them to replace the parking brake motor … it's about a 30 to 60 minute job.
Good luck …. Ann
Reason: Removed deleted quote :(
__________________________________________________ _
2016 RT Limited -- "Jubilee" (as in Cherries)
Guardian Bell (gift from spyderowboy)
ISCI Dual Flag Mount – Tall Poles
Lamonster Bottle Holder and Spyder Cuff
Spyderpops Missing Belt Guard
Spyderpops Bumpskid
Spyderpops Rear Run / Brake / Turn LEDs
Spyderpops Mirror LEDs
Custom Dynamics HMT Brake
Spyderpops Keep Out The Trash (KOTT) Grills
Don't Eat Mud / mudflap
__________________________________________________ __
My 2018 RT LTD did this at about 6500 miles, just as we were leaving on a an 800 mile trip. I disconnected the cable with the above mentioned 12mm wrenches, threw some small blocks of wood in the frunk for chocks, and proceeded with the trip. About half way through the trip, it started working again, so I re-connected the cable. It worked fine for the remainder of the trip, but occurred a couple more times after we got home. I took it to the dealer, and they replaced the cable and servo motor under the factory warranty.
Guys I’ve been getting an intermittent brake failure (light comes on) while riding and standing still. Brakes work fine and light only stays on for a second or two. Happens while riding as well. On for a second then off. No participar pattern, in other words it’s not while I’m pressing the brake. It happens often. Today I was parked, engine off. Turned bike on, light came on and stayed on AND the parking brake wouldn’t disengage. Turned bike off then back on and it disengaged. Drove home but I think it’s time to address. How can I test to see what’s going on?
2012 with 11590 miles. Got it from iMotorSports about 7 weeks ago. Put about 1200 miles on it.
Thanks
Steve.
No, mine did not lock up. It would set but not hold and vehicle would roll.
Cognac 2014 RT-S
I carried a wood block when my brake wouldn't hold, rode 90 mi to dealer to have diagnosed. Part was ordered and when in I was called and had first appointment in a.m. to get new motor installed; took maybe an hour max. The two trips were not a problem in my mind as I could still ride. Had I had the lock up problem, would have done the wrench solution and same first thing install appointment.
Cognac 2014 RT-S
